Honda Accord LXi. I was going to take my honda in for a new clutch, when I pressed down the clutch pedal, and it didn't spring back. It would stay up or down, but not spring back. So I took it to a place, had a new clutch put in. I asked if it was the cable, they said no, it was the clutch. They said the reason the clutch didn't spring back was because the bearing had pressed through the pressure plate and was stuck. Fine. So I had the new clutch.
I drove it for a day, and then, suddenly there it was again. Press the clutch pedal down, and it doesn't come back up. This is with the new clutch. Whatever repair they did obviously wasn't done correctly. Also, another repair not done correctly: the day I got the clutch, after they put things back together, the speedometer wasn't working. I had to take it back to them, and they had a hard time connecting the cable for the speedometer but finally did it.
So now I have to take it back to this place to get the clutch worked on again. (FYI, they also put in a new passenger side axle when they put in the clutch.)
Anything anyone can tell me about what might be causing this? I'm pretty uneasy about having these people work on it again, but it costs enough that I can't just take it to another place to have them work on it.
