hey i found this on preludepower.com.
http://www.geocities.com/b16aprelude...day.31.10.html
a guy did a b16 swap into his 2nd gen lude which is the same as the 3gee. from the looks of it you can use integra axles for axles and front crossmember to utilize the stock b-series front mount. just have to worry about the driver's side bracket for the mount. the b-series mount is wider and the bracket on the 3gee is too narrow. you might have to cut that off and weld in an integra bracket or custom one made of 1/4" steel plate.
as for the rear b-series mount, it looks like it can sit on the stock 3gee rear crossmember. you just have to drill new holes to be able to mount the b-series rear mount to it.
on the passenger side, the b-series has a transmission side mount, but the 3gee doesn't. i think you have to weld in a custom bracket using steel plate again there too for the b-series transmission mount to bolt to.
good thing about this is, you can do all this using stock b-series mounts. just have to find a way to get them to bolt to the 3gee frame rail and this seems to be the way.
this will be my approach to my swap. i suggest you try it out too since you are ahead of me.
if this works, this would be a relatively cheap way to do a b-series swap! (the engine is where most of the cost goes anyways: $200-$900 depending on which b-series you are getting) .....oh yeah, the guy also has pinouts in that site that would help with the wiring process...so check that out too (just go back to the main page and the link for the pinouts is there).
