Results 1 to 16 of 16
Thread: technical turbo question
    SEi User racerx's Avatar
    May 2003
    87 Honda Accord DX
    Colorado Springs
    Is there one specific way to hook up a turbo?
    What I mean is, does it matter which end of the snail the gases enter/exit?
    (either exhaust or intake)...
    I'm trying to figure out the logistics of twin-turbo-ing my dad's jag xjs v12. he wanted me to draw it all out and get some prices, and then he's seriously thinking about doing it!!! so any help is appreciated.
    www.stein-photo.com
    born to XLR8
    2.0Si User Elijah's Avatar
    A20A3T
    Edmonton, Ab, Canada
    There is a intake side and exhaust side. I would just do one big single turbo.
    May 2003
    87 Honda Accord DX
    Colorado Springs
    duh.
    I wanted to know if i went in on the bent (snail) side of the exhaust, and out the middle part, if I could have fresh air come IN the snail side of the intake and out the middle part.
    www.stein-photo.com
    born to XLR8
    NXRacer's Avatar
    86 LXi Hatch
    Tri-Cities, WA
    it only flows one way. no 2 ways about it. there are good sides to doing twin turbo vs single. You're going to have to do a heckuva lot of research to turbo a Jag. I'd suggest you and your dad read up on Corky Bell's turbo book. It'll give you pretty much all the info you'll need.
    Is your dad aware he'll be shelling out a LOT of money to do that??
    Nothin' 2 Old Racing
    May 2003
    87 Honda Accord DX
    Colorado Springs
    ok, look at this picture:
    I want to be able to turn the flow of air around.
    I don't know if it's possible, but it would make plumbling a little more straight-forward and shorter, which is better.
    And yes, we're perfectly aware of the cost of twin turboing a jag. The engine, however, is in perfect condition. 95%-100% compression on all 12.
    The idea is to make it a project. Buy a little here, a little there, etc.
    There's also a guy in town (works for a particular NHRA driver and another LeMans driver) who can assemble it and make all the welds and fabrication necessary.
    We decided on twin because the motor is 5.3L and the two exhaust pipes from each bank never connect. true dual exhaust baby.
    Thanks for the reference to the book for boosting. we'll pick one up.
    www.stein-photo.com
    born to XLR8
    NXRacer's Avatar
    86 LXi Hatch
    Tri-Cities, WA
    like i said, it flows one way. not 2 ways about it.
    the book i was reffering to is titled: "maximum boost" by corky bell. you can pick it up on amazon for like 30 bucks. it will clarify our question probably better then anybody here can.
    bobafett's Avatar
    Stock 86 Accord LXi Hatch
    Longview, WA
    not gonna happen man
    May not be jag specific but the info I posted in the FAQ was most things unspecific about turbocharging... I even listed the books... and as posted before Maximum boost is a good book... I read thru all three I listed in the FAQ and Maximum boost was the best... but a little bias but that wasn't much of an issue since the info was all I was after.
    https://www.3geez.com/showthread.php?t=37169
    Robs89LXi's Avatar
    May 2003
    '89 LXi Coupe
    Can't go backwards. The scroll of a turbo narrows as it goes from entry side to exit. This helps to speed up the air to help turn the impeller wheel (like a nozzle). If you try to go backwards, you will be having the opposide effect and be slowing down the air.
    May 2003
    87 Honda Accord DX
    Colorado Springs
    alright, well it was worth asking i suppose...
    we'll figure it out. i'll post pics of the progress as it goes in O/T.
    www.stein-photo.com
    born to XLR8
    south dakota
    a turbo is an axial compressor connected to a centrifugal compressor via a common shaft. The flow cannot be reversed. Good luck with your project..
    10/Honda/Ridgeline
    NJ
    Does this Jag have twin tbs? is fo stick with twin turbo, even if it does not have has a large plenum, stick with the twin turbo, Pics of the engine bay and power requirement would give me an idea of what size you can run. Also how much boost and what rpm the car redlines at.
    yeah i think they do... they have like a cross ram like a viper
    May 2003
    87 Honda Accord DX
    Colorado Springs
    yes, it has 2 tbs. also the exhaust pipes are true dual, and they never touch each other (6 cyls on one pipe). There's some great places to fit a turbo where a cat is. i'll take pics soon.
    www.stein-photo.com
    born to XLR8
    LX User dub88acc's Avatar
    Jul 2003
    Weber Powered 88 Accord LX
    The Sunshine State
    not exactly a twin turbo v-12 jag; but you can do a similiar set up
    the closer you can get the turbos to the head the better, the hotter the exhaust gases are the more energy there is to drive the turbines, plus with a remote mounted turbo youd have to have a separate oil sump and pump to pull the oil out of the oil drains on the turbos or theyll smoke to kingdom come...
  1. Turbo Question
    By TeamCynic702 in forum Performance
    Last Post: 09-22-2010, 12:06 PM
  2. another turbo manifold question
    By 3rdgeneration in forum Forced Induction
    Last Post: 06-12-2005, 07:44 PM
  3. technical turbo question
    By racerx in forum Performance
    Last Post: 01-31-2005, 01:29 PM
  4. Replies: 4
    Last Post: 12-07-2003, 08:15 PM
  5. Turbo Question
    By od2681 in forum Interior & Exterior Care
    Last Post: 05-07-2003, 10:41 PM
