Results 1 to 8 of 8
Thread: Running Rough...
    DX User AD9SloAccrd's Avatar
    May 2003
    89 accord lx
    Bowling Green, OH
    Unhappy Running Rough...
    Alright, this morning I went out to start my car because it has been freezing out and I hadn't driven my car in a week and a half or so. The car started up just fine, but it was running really crappy. I would try and rev it up a little bit and it just sputtered a lot and really didn't want to go above 3,000 - 3,500. I let it run for a good ten minutes and it really didn't smooth itself out at all. What could it be???
    BTW, the car is an 89 LX
    Thanks
    LX User AccordNut's Avatar
    89 LXi 5spd Coupe Sunroof
    Camp Lejeune, NC
    sounds like you're getting a miss, i remember this happened once to me while changing out the distirbutor/plugs/plug wires. Just inspect your entire ignition system make sure everything is on good and you have clean connections...that might help
    Dec 2003
    So Cal, Orange Co.
    yeah reallycheck out the dist cap, i bet you a dollar that theres a bunch of shit in there. if its not ignition, then you might have to look into rebuilding the carb.....
    Kevin
    Jan 2004
    Bucket
    Bay Area, CA
    carb froozed over? maybe...ha that sux.
    3geez for life.
    A20A1's Avatar
    Sep 2001
    2006 Chevy Cobalt LS
    Did you coolant temp gauge go up at all or reach it's normal spot?... might be that your coolant is still too cold or there isn't enough coolant to warm up the intake manifold and carb so you're having problems getting fuel.
    May 2003
    89 accord lx
    Bowling Green, OH
    It started to go up a little bit, but not to it's normal spot... I've let my car sit longer than this before when it is pretty cold out and it hasn't done that.
    May 2003
    89 accord lx
    Bowling Green, OH
    Hey 88accordhb.... what do you mean by the carb being frozen over. Does that have to do with the outside temp. or something mechanical within the carb is messed up.
    A20A1's Avatar
    Sep 2001
    Its the outside temp... air moving thru the carb is cooled and then frost forms.
    But I doubt it would be a problem as long as the air intake temp sensor, hot-air door and door diaphragm, and pre-heater hose are hookled up and working
    Fuel could also be too cold to vaporise and then you'll end up with puddles of fuel in the manifold that aren't reaching the cylinders. Also if the carb sits too long then the fuel might have evaporated in the float bowl so you'll need to refill the bowl.
  1. Rough running
    By sloweddi in forum EFI Tech
    Last Post: 10-13-2012, 05:14 AM
  2. Running rough
    By 1987AccordLx-i in forum EFI Tech
    Last Post: 11-30-2010, 10:58 AM
  3. Car running rough, any suggestions?
    By 87BLUELX-i in forum EFI Tech
    Last Post: 10-11-2010, 02:51 PM
  4. 89 Accord running rough
    By paulwwww in forum 3geez Accords
    Last Post: 01-02-2010, 03:48 PM
  5. Running rough!
    By bambamky in forum 3geez Accords
    Last Post: 05-21-2003, 10:56 AM
