Results 1 to 5 of 5
Thread: miss-fire
    LXi User Silver86LX's Avatar
    '86 LX Sedan (gone), '89 LX sedan
    Barrie, ON, Canada
    miss-fire
    For the past two days, my car has been miss-firing a bit until it's fully warmed up, then it will randomly do the same if i come to a stop. I changed the spark plugs a few weeks back, and at the same time checked my wires, cap and rotor and all seemed to be in good shape (I changed them last spring which was about 8,000mi. ago). It shouldn't be my timing seeing how that was also checked and adjusted in the spring. Any ideas?
    Thanks in advance.
    - Steve -
    My Accord
    A20A1's Avatar
    Sep 2001
    2006 Chevy Cobalt LS
    The fuel filters... or Sparkplugs
    What heat range are your plugs... you might have the EFI one's make sure you have the Carbureted ones.
    Also check the gap on the plugs.
    SEi User danronian's Avatar
    1989 Honda Accord Lx-i, 1975 Chevrolet Malibu Classic
    Boyertown, PA
    sorry, accidental double post
    Boyertown, PA
    Could be faulty plug wires. I bought these ProConnect lifetime warranty wires and all of the boots and terminals pulled off of them, I know another person with them that had a misfire b/c the one terminal wasn't intalled properly. After it sits awhile you could check the plugs before driving it to see if they are oily, it could be oil running down from the valves through worn valve seals. That wouldn't explain the problem with stopping but that could possibly be a different issue b/c often carbs get flooded when you stop (I'm not sure about honda carbs but from my prior carb experiences this happened alot). Also depending on the brand of plugs, often the plugs will say they are pre-gapped for your car and they often are gapped at the wrong size, so you may want to pull out all of the plugs to check for this. But before doing all of this just make sure all of your plug wires are on the plugs and distributer tight b/c you never want to overlook the easiest fix.
    ANother possibility is corrosion in your distributer cap. If you didn't use RTV on the seal for it they can corrode (unless you replaced the dried up and cracked stock o-ring type seal) real fast and that could produce some spark problems.
    Barrie, ON, Canada
    Thanks for the help guys.
    I had another look this afternoon and the terminal on wire #4 was bent and badly corroded. Also the wire that goes from the coil to the distributor cap was in bad shape as well. I went out and bought a new set of BOSCH wires ($36 CAD) and installed them. It got rid of the miss fire problem and smoothed out the idle. I just dont understand why these wires crapped out so fast. I've had them for less than a year!
    - Steve -
    My Accord
  1. I miss my car!!!
    By Acid X in forum Classic Honda Community Chat
    Last Post: 08-06-2006, 06:01 PM
  2. miss at near WOT
    By 1987HondaAccord in forum 3geez Accords
    Last Post: 09-21-2005, 03:20 PM
  3. Low speed miss
    By accord2 in forum 3geez Accords
    Last Post: 01-25-2005, 05:04 PM
  4. miss firing
    By roni-sei in forum 3geez Accords
    Last Post: 07-28-2004, 09:07 PM
  5. did i miss something?
    By jlaccord89lxi in forum Classic Honda Community Chat
    Last Post: 11-08-2003, 04:39 PM
