well i was having fuel pressure issues not long ago, before my a/c would work fine now when its on at idle the idle drops down as soon as press the button to turn it off its fine........ne ideas?!?! :pimp:
86 Electron Blue Accord Exi
3geez Member since October 31st 2001
the idle should raise when a/c on and drop to normal when off !
does it drop lower than it was before you turned it on ?
MIKE
yeah it drops lower and like starts fluctuating rapidly
does it come back to normal when you give it some gas and let it go ! ?
MIKE
like when i press the gas it revs fine but as soon as let it go it starts doing that again...........when i press the a/c off it goes back to normal![]()
ooooooh god ! you mean your idle is low when AC on ! you can adjust it by adjusting the AC booster screw ! don't know where is that on an EFI accord !
MIKE
