Results 1 to 15 of 15
Thread: 87 LX engine problem
    Feb 2005
    Omaha, Ne.
    Engine operates O.K. when cold and at hot road idle.
    At slower speeds - engine hot - for a split-second - when accelerating or decelerating - the engine bucks slightly as though the ignition switch is being shut off for a fraction of a second. Does it 8 out of 10 times.
    Have changed gasoline, both filters, checked charging system voltage, vacuum lines, (there are a bunch), distributor cap and wires and some of the frequency solenoid valves.
    Any ideas - anyone?
    Thank You.
    Lorin
    Any ideas
    3Geez Veteran gfrg88's Avatar
    1986 Honda Prelude 2.0Si-T
    A Mile High.
    i'm guessing its the oxygen sensor?? maybe i'm wrong.
    have you checked your ecu for any codes. heres the post on how to check them. i'm not positive if thats problem maybe someone else could tell you whats wrong with it
    -Gio
    My E85 Turbo Build
    5280FEST
    Feb 2005
    Omaha, Ne.
    Checked the EGR valve and removed the plastic ECU cover under the drivers seat but this one does not have a window so it looks like I will have to remove another metal cover.
    Weather has turned here and I will resume when it clears up.
    Thanks for the tip.
    86LXItooFAST4me's Avatar
    Dec 2003
    1986 Accord LX-i *** 2002 Mustang GT
    Austin, Texas
    first off, what the hell do you have? 86-87 or 88-89 and is it carb or EFI?
    "Seriously, I have a half o' pack of Rolaids in my dipper" -Stewie (Family Guy)
    Car Pics
    vBGarage
    2.0Si User accordlxi2.0's Avatar
    1986 honda accord lx (r.i.p) 1990 acura legend LS
    chicago , il.
    he has a 1987 LX...so homey you don't have any ecu codes.
    hmmm...whats the mileage??
    ****** 1994 nissan maxima SE ******
    Feb 2005
    Omaha, Ne.
    1987 - Accord - LX - Auto - 119 cid - 1955 cc - 2.0 litre - carbureted - 95,700 mi.
    Don't see an ECU in the Honda manual.
    AZmike's Avatar
    Jul 2002
    Tucson, Arizona
    Did you forget to list the spark plugs in the list of ignition parts you replaced? If not, I'd try swapping them out next; I'd recommend NGKs.
    Mike
    Feb 2005
    Omaha, Ne.
    Bosch platinums at 30K. All O.K.
    Seems O.K. when cold, (below 160F)
    Problem is not missing - it is a stumble or slight cut out only when HOT and at mostly a slight accelerate or on decelerate at slower speeds.
    Idles fine.
    Polar Bear weather here now.
    Will check the Oxygen sensor values and manual section: 11:57/11:59 for frequency control valves A B and C - ASAP.
    Thanks
    A20A1's Avatar
    Sep 2001
    2006 Chevy Cobalt LS
    If the weather was not so cold I would have said it could be the booster venturies coming loose.
    Feb 2005
    Omaha, Ne.
    Unhappy
    Have done a number of vacuum checks on approx 6 items with gauged vacuum pump. All check O.K. according to the Genuine Honda manual except the anti-after burn control solenoid valve.
    It does not hold vacuum on cold test sec:11-102. Ran out of daylight and rain/snow moving in so will continue in a few days.
    As stated: car runs fine cold - idle and all speeds. Hot - near shift points will cut out for a FRACTION of a second, (not a miss on one cylinder) and resume. Locked in 2nd at 2500 rpm - it will cut out and resume 2 times a second. Also, on decelerate - just as you release the gas pedal - will cut out. Feels like the distributor spark advance is sticking on and off. Vacuum test on distributor vacuum advance diaphragm, (vac lines 2 and 25 with distr cap removed), tested O.K.
    Appreciate the response from you guys. Thank You!
    Lorin
    hondamanlxi's Avatar
    Nov 2001
    huntsville, al
    is nebraska a emissions testing state? if not, you need to do the vacuum removal mod. That will clear up alot of wierd little problems, space, and 1 or 2 hp.
    I havent forgotten my roots
    Feb 2005
    Omaha, Ne.
    No emissions testing here since the '80's.
    87accordlxph's Avatar
    Carbed 1987 Honda Accord LX & Black 4th gen Accord (91)
    Petrolia, Ontario Canada
    Maybe the EGR valve is stuck. Plug the vacuum line from it then try to see if the car hesitates on accel. when hot.
    -Mike from P-Town!
    Delete this post please. Damn.
    Mike's Clean Cnd A20A2 5 spd Champaigne Beige Sedan Accord, Eh!
    B-Day: 07/87 in Alliston, ON Canada
    The best mods are mods that can be modded over and over again.
    Feb 2005
    Omaha, Ne.
    Wink
    Had the EGR off earlier. Looked clean, gasket good and plunger seated w/o restriction. Actuated fully with vacuum pump during finger test.
    Will check this suggestion.
    Thanks
    On The Back Of The Carb There Is A Single Wire Connector Going To A Brass Cylinder. This Is The Slow Mixture Solenoid. If This Does Not Have Power The Car Will Run Perfect But Not Idle As If It Was Turned Off (no Bucking, Hesitating) If It Has A Loose Connection It May Cause What You Are Describing, Make Sure It Is Connected Properly. Other Than That It Could Be A Bad Float Setting Or Screwed Up Ignition (especially The Ignitor Unit)
    Eric
  1. engine problem, I think
    By turabaka in forum 3geez Accords
    Last Post: 09-02-2007, 08:26 PM
  2. Wierd Engine Problem
    By allan88accord in forum Carburetor Tech
    Last Post: 04-17-2006, 10:18 AM
  3. Rebuilt the engine!!! Just one problem??
    By Volitech in forum EFI Tech
    Last Post: 10-19-2004, 08:42 PM
  4. need pictures of engine bay to help me fix my problem with engine swap
    By jerky_lxi in forum Interior & Exterior Care
    Last Post: 06-06-2003, 08:43 PM
  5. Engine Problem
    By Admiral in forum 3geez Accords
    Last Post: 10-16-2002, 08:58 PM
