Results 1 to 12 of 12
Thread: Difficulty of auto to manual swap
    how hard ya'll think it is, also how expensive?
    Washington
    20 hrs tops. need basic metric tools and some mechanical skills. id plan from 200+ depending on which clutch you want
    HostileJava's Avatar
    Northampton, PA
    Speak for yourself, mines going on 7 months now, granted I ran into some other problems and stopped when it got to cold out. I doubt you will have the same luck I am having though. I think it's all for the better since the car is getting alot of work done to it.
    shepherd79's Avatar
    Falling Waters, WV USA
    i did the swap in 2 days by my self. the hardest part is getting those pesky pedals in place. there aren't much room to move around. the best thing is to take the clutch pedal out and slide it back on when you have the whole thing mounted.
    Accord of the Year - 2009
    thegreatdane's Avatar
    Jan 2003
    Denmark/Europe
    Compared to an injection convertion it's a real piece of cake. But no it's not hard to do. If you've got the tools, and all the parts you'll be fine.
    Link to my 3geez garage
    maka_RTH's Avatar
    Nov 2001
    '95 Supra, '08 CBR 600RR, '89 LX-i Coupe (R.I.P.), '88 LX-i Sedan (R.I.P.), '87 LX-i Sedan (R.I.P.)
    Orem, Utah
    yah, it's pretty straight forward. if you can remove a tranny, then you'll be able to do it no problem. the most annoying part for me was bolting the troque rod and shifter and stuff together, since i had to reach up behind the exhaust and heatshield.., it was quite annoying to get to/at and i couldn't actually see what it was i was doing. pedals were annoying, but if you drop the entire sterring column.., it goes quite a bit more easily. good luck.
    Greg
    1989 LX-i 2dr 5spd (R.I.P.)
    lol plan 1 weekend
    just make sure you get the rear engine mount, starter bracket, driver side axle, and all the bolts/rubber that hold the shifter in the console. Also don't loose the flywheel bolts, the automatic's bolts won't fit and use locktite on them. The steering column and pedals are definately a pain in the ass and watch the razor-sharp bracket.
    Eric
    87 LXi Hatch (5-speed)
    Riverside, CA
    it took me 3 days, but if i had all the right tools and someone to help me line the tranny up when i was putting it in, it would have been much easier. Once you have all the tools, everything pretty much lines up. my problem was that the brake booster kept moving back when i tried putting the pedals in. damn that was annoying. oh, and i took the whole heat shield out too, and the battery is in the trunk, so that's more space to work with too.
    Idaho
    Took Me 3 Days And Wouldn't Ever Go Back To Automatic!!!! Yippee Skippee!!
    Idaho
    P.s. The Pedals Are Easy Too....lmao....for Me! Muah Muah Muah!
    maka_RTH's Avatar
    Nov 2001
    Orem, Utah
    oh yes, someone mentioned their battery in the trunk. mine isn't in the trunk(for my 4dr), but i removed it and the tray it sits on for more room. it's quite handy having that extra room. and yah, it took me about two full days(this was by myself), and i've dropped a tranny before. plan on a full weekend to do it, just in case. problems always arise of some sort. and yes, i wouldn't go back to auto, i hate auto's
    Greg
    hondamanlxi's Avatar
    Nov 2001
    huntsville, al
    If you have a complete parts car, your set! Its very self explanitory once you ger started! BEWARE, you will probably need a transfusion after putting in the pedals!
    I havent forgotten my roots
  1. Difficulty of auto tranny replacement
    By Clark in forum 3geez Accords
    Last Post: 02-12-2009, 09:06 AM
  2. Trans swap parts, auto to manual
    By irondragon013 in forum 3geez Accords
    Last Post: 12-29-2007, 01:31 AM
  3. auto to manual swap problems
    By msgoose84 in forum 3geez Accords
    Last Post: 03-25-2005, 11:40 AM
  4. manual/auto tranny swap
    By 1987HondaAccord in forum 3geez Accords
    Last Post: 09-27-2004, 10:12 PM
  5. auto to lude manual tranny swap
    By maka_RTH in forum 3geez Accords
    Last Post: 12-02-2002, 09:27 AM
VigLink badge
