Results 1 to 24 of 24
Thread: Simple enough question
    2drSE-i's Avatar
    1989 Honda Accord SE-i Coupe
    Oklahoma City
    in you guy's opinions, what is the cheapest and most effective way to improve the "feel" of my day to day drive?
    im just sick of the feeling every bump and piece of paper i drive over every day, it gets on my nerves lol
    '89 SE-i Coupe
    Awaiting Garage
    So Cal, Orange Co.
    drive around them....
    Kevin
    2drSE-i's Avatar
    Oklahoma City
    lol, i guess my real question is, coilovers, springs or new struts, would be my best bet for making the ride smoother?
    '89 SE-i Coupe
    Awaiting Garage
    So Cal, Orange Co.
    lol, well you said cheapest, and thats what came to my mind.....sorry if i came off like a smart ass, lol. Man just search the freakin suspention section, there is an ample amount of info, good luck
    Kevin
    Feb 2004
    89 accord lxi
    down by the bay
    wait, are you saying the stock suspension feels too stiff? if that's the case you don't want coilovers or lowering springs. just replace the shocks if it's not riding good.
    SEi User 3gn86lxi's Avatar
    Jul 2004
    wa
    you would be amazed what a really good set of TIRES will feel like.
    ~Ryan~
    So Cal, Orange Co.
    well in the case you want it too feel like a caddy, yeah, keep dreaming...... try different tire preasures...
    Kevin
    Vanilla Sky's Avatar
    1999 Penalty Box
    i would be willin gto bet your struts are worn... buy a set of tokicos which are a tad stiffer than stock... stay with your stock springs if you're satisfied with ride height... that's what i'm doing until i can afford the uber bucks for GCs and bilstiens...
    Jul 2004
    wa
    Quote Originally Posted by 88accordalltheway
    yep....it is a small car, you will get small car ride no matter what. if you are not going to lower it, replace your struts, and get some good tires. then deal with the ride.
    ~Ryan~
    I was gonna say tires/rims first.
    Are you riding on 20's then its gonnaride ruff.
    Depending on the tire I usually run 32 frnt 25 psi rear on my tires. There no weight on the back so you dont need as much air in them. Thats about as chaep as i can think of.
    1999 Penalty Box
    i run the opposite on cars i have with matching tires... on mom's car, i run 30 in the front and 32 in the rear... with my mismatched tires, i don't care, it all gets even... i guess it's all preference with precise pressures...
    Quote Originally Posted by Vanilla Sky
    I think it cuts some understeer out of a front drive car.
    1999 Penalty Box
    well, to cut understeer, you want to either increase traction in the front, decrease in the rear, or both... lower pressure means more traction... that was my reasoning... i might try it the other way, but i don't think it's that big of a deal with a street only car... especially one that's not driven that hard...
    2drSE-i's Avatar
    Oklahoma City
    k so the main idea ive heard is, replace the struts (they definately need to be im sure, the stock ones are still on there), wheels and tires (i was thinkin about 16's, if they'll fit) and i wanna go ahead and throw on some coilovers to lower it some, but i can look on those, cuz ive seen alot in the forums, theres even a sticky on the best ones lol.
    Thanks guys!
    '89 SE-i Coupe
    Awaiting Garage
    if you put coiovers, prepare for your ride to bounce on stock or stock replacement struts.
    to support coilovers you need custom struts and they will cost you over $600 green ones.
    coilovers are not the best thing to have if you want smooth and soft ride.
    1999 Penalty Box
    yeah, if you want good struts to go with coilovers, you have to either souce some konis or send biltiend HDs off to be revalved...
    2drSE-i's Avatar
    Oklahoma City
    well ive been wantin to drop it some, and i knew coilovers wudnt help. Will lowering springs require new struts too?
    btw Derick, fix ur sig try using [img] and [/img] around the picture URL :P
    its supposed to be
    '89 SE-i Coupe
    Awaiting Garage
    1999 Penalty Box
    dammit... i fucked up...
    I meant this as a statement of fact not a guess sorry. Worded bad.
    I do have an Lxi so the sway bars might have something to do with that statement.
    Try is its a free deal. Plus I use speed rated tires so maybe I notice the effect better. Plus I like to wear my fronts down pretty good then rotate them to the back so I have fresh tires on the front worn ones in the back for spring time. I like to go up the dragons den RT129 ( 11 miles 318 turns) and play in the spring before the motorcycles take it over.
    2drSE-i's Avatar
    Oklahoma City
    what is soucing koni's? i know koni is the strut brand, but what is soucing lol
    and is it cheaper to get konis or revalved bilsteins?
    '89 SE-i Coupe
    Awaiting Garage
    LX User Defiant[YD]'s Avatar
    89 Accord Sedan LX, 91 ED-7, 2007 Accord EXL
    Cow Town, Calgary
    i found that adding coilovers or lowering springs will give u a harsher ride. looks great, handles great, but harsher ride than stock. i find the stock ride really comfortable as is personally. and yes, u'll need to get new struts if ur getting lowering springs unless u wanna break ur stock ones and get an even harsher ride.
    1989 Accord: Back to Stock
    2007 Accord: Stock
    1991 Civic SI: bunch of stuff done.
    2drSE-i's Avatar
    Oklahoma City
    what is souceing konis?? i know revalving will cost me out the ass, are konis worse or better?
    '89 SE-i Coupe
    Awaiting Garage
    AZmike's Avatar
    Tucson, Arizona
    I prefer the Konis since they are rebound adjustable. However, they haven't made any for more than a year so it's getting very difficult to find them anywhere other than here in the marketplace occasionally.
    ...and the answer to your first question:
    Main Entry: source
    Function: transitive verb
    Inflected Form(s): sourced; sourc·ing
    1 : to specify the source of (as quoted material)
    2 : to obtain from a source <metals sourced from abroad>
    Mike
    2drSE-i's Avatar
    Oklahoma City
    lol he said souce, and are there any websites that still stock them?
    '89 SE-i Coupe
    Awaiting Garage
  1. Simple electronics question, please help...
    By therafiman in forum 3geez Accords
    Last Post: 11-22-2005, 09:13 AM
  2. simple question
    By b8er in forum Classic Honda Community Chat
    Last Post: 11-03-2005, 05:14 PM
  3. Simple question about HU
    By coolcatkoko2000 in forum Interior & Exterior Care
    Last Post: 01-13-2004, 05:02 PM
  4. ok, i have a simple question
    By KoNEY in forum Interior & Exterior Care
    Last Post: 12-02-2003, 09:52 AM
  5. Hatchback S (simple question)
    By Not like a rock in forum Classic Honda Community Chat
    Last Post: 10-15-2003, 12:57 AM
