Hello,
I'm in the process of rebuilding/exploring a spare carburetor and am a bit dumbfounded by the throttle controller. What is it's function? I have also tried applying vacuum to the diaphragm and it doesn't hold. Is this normal or should I get a new throttle controller? Also, what are the sizes of the vacuum lines on the carb? I have found two different sizes so far, one of which seems to be 5/32" (4mm) while the other I suspect to be 5mm (? in) Thanks in advance for any help.
