Results 1 to 15 of 15
Thread: No start, starting relay?
    DX User Dmitry's Avatar
    1987/Accord B20A2
    Kyrgyzstan
    Sometimes, my car (B20A2, 1987) don't starts. Usually it happens, when car is still warm, after 10-30 min. When I turn a key, ligths turn on, I hear the sound of PGM warming up, but that's all. No sound of starter. I try again and again, and usually it starts, but not allways, then I wait 5-10 min and try again.
    My mechanic said it,s a starting relay (pull-in coil?), but I am not sure.
    Battery is OK.
    Quote Originally Posted by Dmitry
    Battery is OK.
    If you dont here the starter yeah its prolly not pulling in. Not too fimiliar with the B motors but the starter is usually all in one on Honda's. It needs a new one. Could check your grounds and other connections also.
    10/Honda/Ridgeline
    NJ
    its most likely ur main relay. A lot of symptoms u described are oriented with it. Just pull the main relay, Driver side under the dash board (check the shop manual). and resolder the solders on the bottom. put it back in and it will work just fine.
    1987/Accord B20A2
    Kyrgyzstan
    smufguy, to resolder all the solders? I checked connections and they looks OK.
    10/Honda/Ridgeline
    NJ
    yes sir, despite the visual checks, do resolder ALL of them, either with the same lead or with a new one, its upto you. it will save u tons of money, and only 15 mts of the solder time, once its done, plugged in and ur good to go.
    1987/Accord B20A2
    Kyrgyzstan
    Quote Originally Posted by smufguy
    OK. I'll try this weekend.
    shepherd79's Avatar
    Falling Waters, WV USA
    even if connections do look good, a small hair crack can prevent the engine from starting.
    Quote Originally Posted by shepherd79
    Again you can jump it out to test it. pins 5 and 7 I think it says in the book.
    I dont see how this wouldnt let the starter engage but hey what the heck.
    1987/Accord B20A2
    Kyrgyzstan
    Ha! Something strange happen! Last week it was very cold (- 24 C at night, -15C day) and my problem disappeared by itself !! I have not even resoldered contacts!
    It's warm again but my problem does not come back!
    I am happy!
    10/Honda/Ridgeline
    NJ
    I am happy!
    dont get ur hopes up.
    1987/Accord B20A2
    Kyrgyzstan
    Yesterday it happened again. I went to car electrician and he dissasembled starter and that cylindrical thing, that located next to starter. I named it starting relay and in manual it is called starter solenoid.
    There are two copper contacts inside solenoid and one of them was burned out.
    Starter itself was OK.
    I replaced solenoid and now everything is fine
    Device error. Driver not loaded!
    Accord of the Year - 2009
    thegreatdane's Avatar
    Jan 2003
    Denmark/Europe
    Kyrgyzstan? Is that in Poland?
    Link to my 3geez garage
    1987/Accord B20A2
    Kyrgyzstan
    to thegreatdane
    Poland?
    A kind of.. Eastern part of Poland )
    Just between China, Uzbekistan and Kazahstan.
    LX User snow_man_20's Avatar
    89' Accord LXI
    oregon
    If the main relay is bad, i thought it will still crank but no start. And also if it's bad you wont hear the fuel pump when you turn the key to the on position. Also you won't hear a click when the "check" light turns off.
    Mabie i'm wrong
    10/Honda/Ridgeline
    NJ
    when my main relay went bad, it did nothing. some other relay was clicking everytime i tried to crank, but no starter or pump cause the relay controls both. SO the engine stayed still.
  1. Changed relay still no start
    By stevo89 in forum 3geez Accords
    Last Post: 06-08-2010, 05:27 PM
  2. Problem Starting (hard start)
    By Timaculent in forum 3geez Accords
    Last Post: 01-14-2006, 08:26 AM
  3. starting issue, main relay?
    By AccordNut in forum 3geez Accords
    Last Post: 07-24-2005, 07:30 PM
  4. 89 SEi - starting problems (AFTER new main relay)
    By themendios in forum Performance
    Last Post: 06-18-2004, 08:12 PM
  5. main relay location starting malfuction
    By MobFigganugga in forum EFI Tech
    Last Post: 08-13-2003, 10:44 AM
