Ok I did a search and couldnt come up with a straight forward answer. Is the b20 a direct swap into our 3geez. If not what is needed?
The JDM Accord B20A (not any other engine designated as B20) will directly bolt in place of the A20A. I believe the information for the swap, including particular engine codes and serial numbers that can be used, is included in the FAQ/How-to section. That should answer all of your questions about the swap.
All you ever wanted to know about the B20A: https://www.3geez.com/showthread.php?t=86
3axap.
