Results 1 to 7 of 7
Thread: Tricks in getting Crankshaft Pully out?
    Aug 2003
    1998 Nissan 200SX SE-R & 1989 Honda Accord LX
    Marietta, GA
    I've searched but didn't find the info I'm looking for.
    I got the crankshaft bolt off yesterday (not as hard as I thought it would be). The pully is not budging. Do I need a special tool (pully puller type tool) or should it just slide off? I tried some WD40 to try and penetrate in, but it's still not moving
    Maybe I need more muscle?
    Sam Bass
    Marietta, GA
    Feb 2004
    1988 LX Sedan
    East TN
    The pulley should slide off easily. It's a slip fit with a small key. Try some WD40 and let it set for a few minutes. You may have to use a rubber hammer if the pulley is rusted on. If you have to use a puller, be sure to use the pulley bolt or something else to protect the crankshaft threads or they can get damaged from the puller. Good luck.
    10/Honda/Ridgeline
    NJ
    try to wedge something between the block and the pully base and pry it out, but wd40 soaked and rubber mallet impact will free up the rust/oil freeze.
    Quote Originally Posted by HostileJava
    Have you looked over the howto?
    https://www.3geez.com/showthread.php?t=15450
    he wants the crankshaft pully out jimmy, not the camshaft pully.
    LXi User buds302's Avatar
    Jun 2004
    90 civic hb R.I.P. , 2002 EBP EM2<<figure it out..its not that hard
    new castle pa
    three jaw puller got mine off
    b u n n y · t y p e R
    "the bunny liked the go-faster stripes... but wasn't too keen on the rear spoiler and ridiculous bodykit"
    Quote Originally Posted by buds302
    puller
    rent one
    Aug 2003
    Marietta, GA
    I'll try some PB blaster and a rubber mallett before I go buy/rent a puller - thanks all!
    Sam Bass
    Marietta, GA
  1. Crank pully will not come off.
    By dawlfandave in forum 3geez Accords
    Last Post: 11-30-2007, 10:04 PM
  2. Help with Crank Pully and Timing Gear.
    By HostileJava in forum 3geez Accords
    Last Post: 07-14-2005, 12:56 AM
  3. Pully Bolts
    By 86ACCORD2.0CARB in forum 3geez Accords
    Last Post: 05-05-2005, 03:48 PM
  4. Under drive pully set
    By Elijah in forum Performance
    Last Post: 01-07-2004, 06:55 AM
  5. Alternator pully
    By 89accordtre in forum Performance
    Last Post: 07-14-2002, 10:53 AM
