Results 1 to 11 of 11
Thread: Alternator?
    LX User Ace's Avatar
    1992 Honda Accord EX
    North Smithfield R.I
    Alternator?
    I just bought a new optima battery yesterday today I went to start car
    and I got nothing I broughtback battery for new one and it works fine now. Ive heard a bad alternator can drain the battery when I unhooked battery cable after letting it run it still ran though any suggestions on what it is
    Dec 2003
    So Cal, Orange Co.
    do you have a stereo with an amp? if you do check your power wire, it might have gotten grounded. Also make sure the posts on the battery are clean and have a good connection on the battery connectors.
    Kevin
    I checked all that still nothing and no amp
    SEi User danronian's Avatar
    1989 Honda Accord Lx-i, 1975 Chevrolet Malibu Classic
    Boyertown, PA
    I've had many faulty batteries, mostly diehards, but that could have been it.
    I talked to a mechanic and he says that it may of been something not turning off killing the battery is this pratical?
    Boyertown, PA
    If the only thing you changed was the battery and then the next morning it was dead, it was probably the battery or the connections to it being corroded or broken. If you are replacing the battery because the prior one was dead, then you need a battery charger b/c until you fix this draining probelm you will be dealing with many dead batteries.
    If you explain your problem fully we will be able to help, if not, we can't help.
    About the mechanic, yes maybe a light is draining the battery but it is not likely one light bulb on all night would fully drain a new battery. I have done that many times with old batteries and they started slow in the morning, but never died. Then again if it was -20 outside with the light on, that could have killed the thing. There is too many variables before you completely explain what is wrong with your car.
    yea I will just wait to bring it to him It may has well be the battery but I will have him check it out thanks for the input
    well here we are 2 weeks later 2 mechanics and I still cannot find the problem I have drained 2 optima batteries I tested all the fuses with a voltohmeter seems fine mechanic did same thing. The thing is the voltohmeter dropped drastically when we unpluged the power to the alternator My mechanic said though that a voltohmeter could be 2 sensitive? what do you guys think?Is a voltohmeter that sensitive he said he wasn't sure how accurate the reading was He suggested I go see a electrical specialist$$$$$$$$
    2.0Si User
    May 2004
    1988 Accord DX
    SEMO
    Quote Originally Posted by Ace
    Typically, when you unplug the battery cable, the car should stay running. If it doesn't, your alternator is bad. That is not a good method of testing the alternator with cars that have an ECU, it could ruin the ECU, but normally would indicate a bad alternator.
    You ready to laugh my father this weekend was helping me find a oil leak and took aout is test light found the problem i 2 minutes a head light motor was jammed and woas not closing correctly the motor kept straining to put the battery down which led to it running constanly which was the reason the battery was draining
    2.0Si User
    May 2004
    1988 Accord DX
    SEMO
    Yeah, be surprised what a simple little 6/12 volt test light can do. Go dad..
    That reminds me of a problem I had. That stupid light bezel that goes around the light caught my bumper frame & drained my battery too. I had just enough juice to push start it in 2ng gear.
  1. 87 lxi alternator
    By tomsmith in forum 3geez Accords
    Last Post: 03-31-2007, 09:03 PM
  2. Alternator / alternator light pbs
    By lionel in forum 3geez Accords
    Last Post: 12-13-2005, 01:36 PM
  3. Alternator!!!!!!!!!
    By soljaboy2000 in forum 3geez Accords
    Last Post: 03-31-2004, 03:30 PM
  4. alternator?
    By Elijah in forum 3geez Accords
    Last Post: 03-07-2004, 08:25 PM
  5. Alternator?
    By c20v6turbo3rdgen in forum Performance
    Last Post: 07-16-2003, 12:23 AM
