Some people on here say the A20A block and crankshaft can support 400 hp and some others say it can support only about 150 hp. It can't be both. I thought the reason they built an F22 was because it was more rigid and could support more power. I thought if you tried to make more than about 130 hp with an A20A the block starts to flex because even though its cast iron its very thin cast iron, it does't have forged rods or pistons, it has a heavy cast crankshaft, and there is no bearing cap girdle thing...
...a B series with a block gaurd will be sturdier.
I looked it up last night, cast iron has a slightly lower yield strength than aluminum.
Turbocharged or N/A ?
What speed is a 200hp A20A, Can the block go to 8500?
