Results 1 to 6 of 6
Thread: Ignition switch
    86/honda/accord dx
    humboldt county
    Ignition switch
    After my car was vandalized, I found out they had screwed up my ignition switch...is there anyway that I can replace it all myself including takeing it off of the steering colume or do I have to take it in to someone???
    89 Accord LX-i
    Central Oregon
    You can remove it yourself, fairly simple job. I will recommend you take the locking cylinder(where the key goes) to a locksmith and have them fix it. I bought 3 or 4 new ones that did not fit my car. When you have the cylinder out, check the actual switch to make sure it is OK. You can start it with a screwdriver, and it should stay running, by inserting a flathead screwdriver into it and turning. Mine would flip back to ACC position and shut the car off. A new switch was about $60 from Honda. Good luck!
    "Without high school drop-outs,
    some guys would starve"
    Easy Money
    A20A1's Avatar
    Sep 2001
    2006 Chevy Cobalt LS
    Just don't forget to disconnect the battery.
    86/honda/accord dx
    humboldt county
    the locking cylinder is what I mean to say, thats what I want to remove or do I need to take it to a lock smith, right now I have been using a flat head screwdriver to start it lol
    89 Accord LX-i
    Central Oregon
    No, you can remove it yourself. It's been awhile, but all you have to do is take off the panels around the steering column(I think) and then there is a small tab you push in with a small allen wrench(I think you need to have it in the ON position while doing this) and it should come out, then take it to a locksmith. I think I payed $13 to have mine fixed, instead of $30 for a new one from Napa, etc... that kept giving me the wrong one. Honda doesn't sell just the cylinder, you have to buy the whole kit and kaboodle for $200+ dollars! Once you get the cylinder out though, check the switch itself, you only want to do this once!!
    Easy Money
    86/honda/accord dx
    humboldt county
    Hey thanks for the help, im gonna give it a try and see if I cant get that bastard out of there lol.
  1. Where is the ignition switch?
    By Dia Fria Claro in forum 3geez Accords
    Last Post: 11-10-2003, 07:25 AM
  2. Ignition Switch??
    By 88' Accord Ltd in forum 3geez Accords
    Last Post: 05-16-2003, 09:27 PM
