I'll get ahold of eaton, even if it isnt top feed charger (because it is off of an EFI car) we can always make a bracket on the intake side with a tube to have the carb upright.
If we get a carb off of a 350, make the barrels manual, what other vacuum stuff do we have to worry about?
How would we make it work so the power valve opens properly? Maybe I missed that part of carbs in high school. What can we convert to make it work?
IMPORTANT
What can we do about venting excess pressure? My friend has this idea of a seperator to seperate the air/fuel, return the fuel to the tank and blow off the air. But what can we use a seperator?
EDIT:
The email I sent to Eaton. Link to their siteHi there, I have a some-what wierd question to put across you.
I am building up a honda carbuerated motor and am building a pull-through charger system to power it.
I have access to an M90 charger that we plan on using to pull through a 500cFm 4bbl carb.
One of the major problems that has arisen (even though we are good fabricators) is that we havent built a pull through system before, and our main question is if this blower is capable of compressing air/fuel up to 5-6psi into a custom made intake manifold. (bypass/blow off is not a big issue right now)
All of our blue prints are ready and we have access to an m90 for a very reasonable price.
But like I said, we are worried about the air/fuel in a roots charger, we dont want to end up blowing ourselves up.
I was told to go directly to the source to ask if this application would work for the blower.
We would very much appreciate a response. Thank you for your time.
and I hope to get a response shortly.
By the way, I should have my 3 pages of notes/diagrams up tonight, I have a scanner now but I have to go to work.
IMPORTANT
How would we go about doing the pcv? I havent checked how it works stock on our engines, but I would assume it would have to be hooked up to vacuum and not boost :p
