Page 1 of 6 12345 ... LastLast
Results 1 to 25 of 132
Thread: INTAKE MANIFOLD ( Modification / Design / Fabrication )
    A20A1's Avatar
    Sep 2001
    2006 Chevy Cobalt LS
    Post INTAKE MANIFOLD ( Modification / Design / Fabrication )
    Intake Runner Length (L)
    Knowing that the pressure waves (positive or negative) must travel 4 times back and forth from the time that the intake valves closes to the time when it opens and the speed of the pressure waves, we can now figure out the optimum intake runner length for a given rpm and tube diameter. We must take into account the intake duration, but you want the pressure waves to arrive before the valve closes and after it opens (air wont pass though a closed valve). To do this you must subtract some duration, typically you take off 20-30° from the advertised duration. 30° works well for most higher rpm solid cammed drag motors. So the Formula to figure effective cam duration (ECD) will be:
    ECD = 720 - (Adv. duration - 30)
    For a race cam with 305° of intake duration it will look like this:
    ECD = 720 - (305 - 30)
    The ECD of that cam would be 445
    The formula for optimum intake runner length (L) is:
    L = ((ECD × 0.25 × V × 2) ÷ (rpm × RV)) - ½D
    Where:
    ECD = Effective Cam Duration
    RV = Reflective Value
    D = Runner Diameter
    If our engine with the 305 race cam needed to be tuned to 7000 rpm using the second set of pressure waves (RV = 2) and had a 1.5" diameter intake runner the optimum runner length formula would look like this:
    L = ((445 × 0.25 × 1300 × 2)÷ (7000 × 2)) - 0.75
    So 19.91 inches would be the optimum runner length.
    ECD = 720 - (288 - 30)
    ECD = 720 - 258
    ECD = 462
    The ECD of that cam would be 462
    __________
    V = ???
    RV = Reflective Value (why does it = 2?)
    D = Runner Diameter (Inner diameter)
    If our engine with the 288 race cam needed to be tuned to 7500 rpm using the second set of pressure waves (RV = 2) and had a 1.50" diameter intake runner the optimum runner length formula would look like this:
    L = ((462 × 0.25 × 1300 × 2)÷ (7500 × 2)) - 0.75
    L = ((300,000)÷ (7500 × 2)) - 0.75
    L = (300,300 ÷ (15000)) - 0.75
    L = (300,300 ÷ 15000) - 0.75
    L = (20.02) - 0.75
    L = 20.02 - 0.75
    L = 19.27
    __________
    Well out comes the firewall.
    I want to know what the v stands for... if the value is wrong so is my calculations.
    the formula I got is from browsing the net.
    Jun 2002
    1989 Accord Exi
    Canada
    Exclamation INTAKE MANIFOLDS ( Selection / Design / Fabrication )
    Has anyone attempted this. I have all the resources to do this, I just dont know where exactly to start. Longer runners or shorter, etc..... It would made completely out of stainless steel.
    Nov 2002
    Ridin Dirty in New York
    longer runners will give you more peak torque but short runners give you high hp on the top end. Ive never seen anybody attempt making a custom intake for an a20.
    Jun 2002
    1989 Accord Exi
    Canada
    i work at a stainless steel tubing manufacturer. i have access to everything except a lathe and a milling machine.
    Mike's89AccordLX's Avatar
    Mankato, Minnesota
    I have a short ram intake and I'm putting a hoodscoop right above the filter.
    PhydeauX's Avatar
    Eastern Penna
    Idealy you want trumpet shaped runners with flairs on the ends.
    http://www.sdsefi.com/techinta.htm
    Some nice pictures on how to do it, look at the toyota 22R manifold near the bottom.
    http://www.billzilla.org/inlet.gif
    A chart for calculating inlet length. The total length from the valve to the end of the trumpet is calculated so you need to subtrace the length of the port to get the runner length.
    Remember that b16a, b18a, and b18c5 manifolds can be easily adapted to fit on our motors. So make sure you do your homework and come up with a good design, because you can easily enough pick up an ITR manifold off ebay for a few hundred, drill a few holes in it, and your good to go.
    andy
    Mankato, Minnesota
    Ahh crap we're talking about intake "manifolds." I'm interested in getting a custom manifold.
    Nov 2002
    yeah also you need to have it taper in and then flare the ends, it in creases velocity and thats how the honda and most other manufacturers design it
    1989 accord lxi coupe
    rhode island
    the intake manifold fomr bseries fits our cars , do the ports line up i know te bolt holes dont?
    damn accord always in the back of my mind!
    bobafett's Avatar
    Stock 86 Accord LXi Hatch
    Longview, WA
    1/2 the bolts do!
    rhode island
    i would like to know why this is a performance mod, the civic intake is for a small displacement engine, also the bolts arnt a proplem its the ports do the ports line up, im am not nocking the idea but just questin it, has anyone seen or notecd and gains in this i would like some solind info
    thanks,
    Kevin
    Jun 2002
    1989 Accord Exi
    Canada
    and what about port-matching? if there is the slightest difference it will produce a bad swirl
    Jun 2002
    1989 Accord Exi
    Canada
    i'm also working on a CAI with a velocity stack(reducer) from 3" to 2.5" just before the throttle body. Anyone else try this?
    IWLSF's Avatar
    91 GSX - 89 Si - 87 DX
    Oklahoma
    Damn, intake runners for a 22R? That's tje same motor in my pickup...
    Jan 2003
    1986 prelude
    charlotte nc
    itbs maybe
    Quote Originally Posted by fromerly89Exi
    hey see if u can make an itb for me for the a20a3 ill pay whats reasonable thnx
    A20A1's Avatar
    Sep 2001
    Look for the B16A or B18C5 manifolds
    they have the same ports as us just slightly different mounting stud positions which is fairly easy to fix.
    REDLINE WEBER ITB
    Sabz5150's Avatar
    1989 Accord SE-i coupe
    Richmond, VA
    Individual Throttle Bodies.
    That is all.
    glorious!
    SEi User
    south dakota
    I think the LS integra manifold would be the best option for a street driven car. It has a large plenum, and long big runners, and its engine has the most similar powerband to the A20 of the b series. (Except the b20, but that manifold is huge, it sticks up like a tunnel ram). I have the aebs typhoon manifold for the B16/B18C5, but the reason I chose that is that of the aftermarket b series manifolds, it is the only one I could find that showed good gains all over the powerband, unlike the edelbrock unit, and I believe it also has a larger plenum than the skunk2, which I was previously considering.
    Also, I have this theory about how forced induction moves the volumetric efficiency curve of an intake manifold upward in the rpm range, so this may make the LS manifold an even better choice for those who want to go with forced induction..
    As far as designing and building a completely custom manifold from scratch, that would be ill to the fullest, and I was actually considering doing that at one point. (I still have the flange) The reason I didnt is if you don't know the formulas for plenum volume, runnner length, runner taper, etc, etc, (I admit I don't) you are going to be building and dyno testing a lot of manifolds before you get one that delivers what you want. I would recommend starting out by at least trying to copy one that is a known quantity, and then going from there.
    10/Honda/Ridgeline
    NJ
    Exclamation MODIFICATION, Turbo Intake manifold selection
    Alright, after a long research it is common sense that the B series intake manifolds modded to fit the A20 motors are the best to use for Turbo application. Then comes the question of what kind of design should the intake manifold carry to utelize the maximum flow of pressure with minimal restriction. Larger and streamlined plenum with short runners are the best for the application despite the engine rpm since its forced induction. Instead of slapping on widley used or recommended intake manifolds, i would like to list pretty much all the good quality manifolds available off the shelf for good companison and pick out the best at hand. The following images/products are the manifolds i want to choose from and recommend it to people who are along the lines of turboing their car since the quality of these are superior and reliability is great. So here are the following.
    BBK (around $120)
    Edlebrock ViictorX ($220 to $350)
    Venom ($500 to $600)
    JG Engine Dynamics {Endyne} ($ unknown)
    AIR Endyne ($400 - $500)
    NOTE: The reason for the comparisons is purely based on performance on these manifolds and valid technical responses only. All the bullshit and offtopic posts will be deleted by a mod upon my request to keep this thread clean and specific.
    PS: Price is not an issue so do not use it as a reason. If price was a reason for me, i wont be undertaking the turbo project and neither would have many who are under way. I have a pick in my mind with reasoning behind it based on my engineering. Aside from that, i would like to hear what people think would be good based on their experience either personally or thru their friends. Thanks fellas.
    Nov 2002
    you forgot the AEBS intake mani
    10/Honda/Ridgeline
    NJ
    like i mentioned above these are my selections. I did look over it and i disregarded it for the same reason i omitted skunk2. They have much longer runners than the AIR Endyne (longest runner of the pack). and their plenum design and volume is not what i desire.
    Nov 2002
    the skunk 2 isnt that much better than the the stock B16/B18C5 intake mani, but the AEBS is one of the best ones for the money ~$150 ish
    NXRacer's Avatar
    86 LXi Hatch
    Tri-Cities, WA
    i'm assuming that the BBK will accept aftermarket fuel rails like AEM etc. Thats a pretty nice price for an IM. Its hard to find good stock B series IM's for that cheap.
    this has got me thinking. . . . . .
    Nothin' 2 Old Racing
    10/Honda/Ridgeline
    NJ
    no fellas, im not talking about the price at all. or what it would accept. Im asking which one will flow good cause all these flow differently and neither of you so far replied to what i asked for.
    Nov 2002
    as for flow it probably goes like this...
    Victor X>BBK>Venom>JG, Endyn>AEBS>Skunk2>Stock B16/B18C5
  1. Replies: 0
    Last Post: 08-27-2011, 02:44 PM
  2. CUSTOM , HEADER ( 4-1 & 4-2-1 / Selection / Design / Fabrication )
    By A20A1 in forum Restoration & Custom Fabrication
    Last Post: 07-08-2006, 05:31 AM
  3. Replies: 2
    Last Post: 05-06-2005, 09:11 PM
  4. possible turbo manifold design
    By NXRacer in forum Forced Induction
    Last Post: 09-15-2003, 08:08 AM
  5. possible turbo manifold design
    By NXRacer in forum Performance
