'89AccordLX(Rus)
Hello,
Recently I started hearing a quiet but persistent whistling noise coming from the right side of my car. Since the noise wasn't affected by braking or engine RPM, I logically assumed its one of the wheel bearings. Because the rear bearings are so much easier to change, I decided to inspect the rear first. The protective cap on the bearing is covered in grease, as it has been ever since I got the car. There is also evidence of oil/grease around the edge of the cap. I removed the drum and spun the hub alone. No binding or rough spots could be detected, nor any noise. What surprised me though, is that the hub didn't rotate as easily as I imagined a ball bearing hub would. I could feel somewhat of a resistance while spining the hub. The whole time, the operation was smooth and quiet. Is it normal for the hub to spin with a slight bit of resistance? Also, since our wheel bearings are sealed, would the grease indicate that the bearing is heading south? Thanks in advance for your comments.
