i took out my motor and my window today to determain what my problem is why the window wouildn't go up. The first problem was the switch itself, so i took it apart and cleaned up the contacts and tried it out. It worked with the motor out of the door and with no window. So i figure great, should work in the car. I put it all in the car and get the window attached and try to roll it up just enough to tighten the two bolts and it went up too far and stopped. I tried to get it to go down but nothing. I could hear a clicking sound when i swiched directions( i would assume the sparks from the built up electricity in the motor). Then i tried running 12v directly to the motor like pauls manuel says. Tried both ways and nothing. It would jump but not move either way. .... any ideas?
this is on my 90 accord, but the wires are the same color and other things are the same too...
