Results 1 to 7 of 7
Thread: How to build a budget a20(long)
    hondamanlxi's Avatar
    Nov 2001
    huntsville, al
    This is the result of the "Budget motor build q's" thread
    HEAD
    -replace all valve springs
    -replace all valve guides
    -replace all stem seal
    -port/polish/deburr head
    -cut .07 off the head
    -DONT BUY A BAD CAM(this just saves time lol)
    -reuse head bolts(optional)
    BLOCK
    -cut .02 off the deck
    -hone out wrist pins slot .01 over(less friction)
    -polish crank .01 over (less friction)
    -reused stock pistons/rods after inspection
    -hone cylinder walls
    -acid dip everything including the oil pan
    -Replace oil/water pump
    -Rering and rebuilt bottom end
    -arp rod bolts/nuts
    special thanks to RJUDGEY! thanks for your help!
    GRAND TOTAL: >$1000
    My compression is 250psi per cylinder (10.5/1 est) and it really shows! All this stuff just enhanced all my previous mods....
    -centerforce dual friction
    -prelude si trans
    -b16a "power plus" mani
    -fpr/walbro 255
    -header/2.25 piping
    -msd 6al/blaster 2 coil/slotted dist for more advance
    -no mani cooling(heating really) system
    -4th gen MAP sens
    -no emissions/ps/ac
    -Nx wet kit... This is where it all came together! Now, when i spray a 75shot it makes the previous 100shot look weak!
    GRAND TOTAL: <$1800
    and... i got some black Rota subzero's in exchange for my RH c2's. So all in all, its been a good winter
    I havent forgotten my roots
    Vanilla Sky's Avatar
    1999 Penalty Box
    wow, i'd like to see it dyno'd...
    couple things i would do different if i had the time and money, are:
    pistons (at the least swap up the 88/89 LXi pistons [i have a DX])
    head studs
    a good cam
    possibly rods
    was that total with you doing the work, or a machine shop doing it?
    Nov 2001
    huntsville, al
    i did all i could do and the machine shop did everything else. All the cutting/p&p was machine shop.
    The expensive parts were: All new valve springs,clutch, and block machine
    work
    After i get a hold of the previous owner of said bad cam, im getting a colt triflow cam
    1999 Penalty Box
    you said in your other thread that 4 other people have owned that cam? mind PMing me who and all has owned it?
    SEi User
    Jan 2004
    Long block
    Nice one!!
    Actually you got something on their that i've not tried, the piston pin honing, hmm allwasy have a problem with them tightening up, will give that a shot next time!! Might solve a few issues!!
    Glas it's getting their you was getting us all worried with that cam problem!! Any ideas on what your gonna put in their instead?
    LX User snow_man_20's Avatar
    89' Accord LXI
    oregon
    $1000?? That is a good price, Is that with all honda parts too??? I think i'm going to start a rebuild this summer.
    see thread
    https://www.3geez.com/showthread.php?p=499251#post499251
    Nov 2001
    huntsville, al
    OEM and ARP
  1. Budget
    By Bullit in forum Performance
    Last Post: 12-27-2005, 07:02 AM
  2. Budget T/B swaps!?
    By hondamanlxi in forum Performance
    Last Post: 03-28-2005, 04:47 PM
  3. budget motor build q's
    Last Post: 01-18-2005, 02:39 PM
  4. Performance on a budget!
    By 1989 DX R in forum Performance
    Last Post: 11-18-2002, 06:47 AM
  5. $500 +/- suspension budget...
    By bobafett in forum Suspension/Wheels/Tires/Brakes
    Last Post: 06-09-2002, 10:58 AM
