Results 1 to 25 of 36
Thread: Finally slammed w/ Konis & Suspension Techs
    2.0Si User
    May 2004
    1988 Accord DX
    SEMO
    Cool Finally slammed w/ Konis & Suspension Techs
    delete this, outta here.
    SteveDX89's Avatar
    2002 Mazda Protege5
    New Freedom, PA
    Looks good. Lowered 3g's look so much better. What struts are you using in the back?
    Busted_Blue's Avatar
    Jul 2003
    93 civic
    San Francisco, CA
    probably tokicos.
    looking good.
    2.0Si User
    May 2004
    1988 Accord DX
    SEMO
    Quote Originally Posted by SteveDX89
    Thanks Steve. I'm just running on stock shocks in the rear.. . I'm going to wait till they blow. I know what I have to do to get that back stut out now. The bottom bolt doesn't come out, looks like I will cut it & have new bushing pressed in. I want to get some sway bar bushings too, kind of pink looking...
    looking good.
    Thanks again.
    NXRacer's Avatar
    86 LXi Hatch
    Tri-Cities, WA
    coupe's look so sexxy slammed. i've noticed that the back end usually tends to be lower then the front.
    Nothin' 2 Old Racing
    SteveDX89's Avatar
    2002 Mazda Protege5
    New Freedom, PA
    Quote Originally Posted by NXRacer
    'Tis an illusion. At least on my car. If you look along the bottom under the door, it's level with the ground. I think it might be a tad higher in the back. The rear wheel wells aren't cut as high as the fronts.
    Jan 2004
    Bucket
    Bay Area, CA
    lookin good dereck.
    3geez for life.
    HostileJava's Avatar
    Northampton, PA
    Looks good, but why do the pics look a tad distorted?
    SEi User frankie89's Avatar
    Aug 2004
    rollin on foot...
    ALLENTOWN PA
    nice drop!! looks really good
    R.I.P....89 LXI 12/28/05
    R.I.P....91 LS 8/11/07
    SEi User jigga225's Avatar
    Louisiana
    slammed is good man.
    now gotta do something about those eyelids
    Washington
    hey do the JIMS 1/2 in front drop. I need to do it on my coupe. Ive got konis on all 4 on sprints with the addcos and dc front brace. Thing rides on rails but needs the a little less fender gap in front. Mike
    2.0Si User
    May 2004
    1988 Accord DX
    SEMO
    Thanks for all the comments. Couple of the pics are little distorted cause I was in a hurry & didn't have the camera on the right setting.
    Quote Originally Posted by mykwikcoupe
    Not sure what you mean?
    Feb 2004
    89 accord lxi
    down by the bay
    he's talkin bout cutting the front pinch forks.
    SEi User 3gn86lxi's Avatar
    Jul 2004
    wa
    Finally Dereck lowered his expectations!! Drop looks sweet maing.
    Good job bro. :alc:
    ~Ryan~
    SEi User Low Tek's Avatar
    lookin
    Portland Oregon
    hell yea.. love the drop look. I have to do mine the right way.. I have the stuff, just need to get it done. mine will be 2 1/4 rear, and the 2.5 in the front.. hope that helps.. if not, I will shave it down more - I hate gap
    'honda makes people happy'
    2.0Si User
    May 2004
    1988 Accord DX
    SEMO
    Quote Originally Posted by 3gn86lxi
    Good job bro. :alc:
    Thanks bud. Ha ha, lowered expectations.. Wish the cost was lower to be dropped. "You got to break bread if ya wanna be slammed"
    Here is some things I want to say to people that might want to lower there car. The rear (stock) spring doesn't have much pressure on it. I had to take it loose from the top to get the spring off cause the bolt on the bottom doesn't come out. It most likely is froze up. The bolt on the bottom of the strut assembly on the front didn't come off. I had to knock the strut out from the bottom on one side. Another words, give yourself plenty of time for setbacks. Make sure you get all the bushings on the top of the strut right.
    Quote Originally Posted by Low Tek
    Thanks, them the lude arms I bought from you back when Mody Dick was a minnow.
    SEi User danronian's Avatar
    1989 Honda Accord Lx-i, 1975 Chevrolet Malibu Classic
    Boyertown, PA
    Looks good.
    bullard123's Avatar
    Nov 2003
    1988 Hatch LXI
    COLORADO SPRINGS
    I don't know. It seems like my rear is actually lower than my front, not by much ,but when I bottom out its always in the rear and never in the front.
    SteveDX89's Avatar
    2002 Mazda Protege5
    New Freedom, PA
    Did you use an air gun on the lower one in the rear? I did and it came right out. The front ones, however, never came out. I had to have someone step on the lower arm to push it down the whole way and then rotated the top of the strut out toward the outside of the car. Was a bitch but it worked. Only took me 14 total hours to lower mine.
    2.0Si User
    May 2004
    1988 Accord DX
    SEMO
    I used air tools on everything. 1/2" Impact did break it loose, but the bolt won't slide out the bushing. Will have to cut that bolt when I put new struts in the back. Here is all my problems I had.
    1. Back bottom bolts on rear strut didn't come out. Took spring out the top.
    2. Bolt on bottom of one side of front fork didn't come out. Took out from top.
    3. Bolt on top of one front strut didn't come off. Had to cut the nut off even at the top.
    4. Instructions with Koni struts suck. Had to pull the front struts back out & put old bushings in.
    5. Still have to get longer bolts for the back & do washer trick for camber.
    6. Needs alighment next.
    Took about 7-8 hours so far.
    Not like a rock's Avatar
    86 EXi(sold), 89 SE-i auto, 89 SE-i 5spd
    Prince George, North BC, Canada
    Koni Instrucions
    I'm going to be putting my Konis in as soon as my springs arrive, can you give any more details on which bushings you need to put back in? And that white plastic washer that comes with the Konis.... I'm not clear on where that goes.
    Nice drop, btw.
    edit: nvm, I see the corresponding thread in suspension section
    Perfection is simply a matter of replacing parts.
    Mike's89AccordLX's Avatar
    Mankato, Minnesota
    I'm cutting my spare wishbones today 1/2 lower in the front is nice. I have Tokico Struts and Tokico Springs. I'm finally going to get to put them on too. Suspension and Steering class yo! My instructor recommended that we check our own cars. And since my springs are sagging on one side it will be my excuse to throw on my struts and new springs. I wont have it slammed but it should take up most of the wheel gap with my 17's installed. It will be 1.5" in the front and 1" in the rear.
    The drop looks good, keep up the progress.
    2.0Si User
    May 2004
    1988 Accord DX
    SEMO
    Quote Originally Posted by Mike's89AccordLX
    Yeah, it took me a long time before I put my springs on. I had some riff raff about buying some Tokicos on here. Anyhow, I didn't know about cutting the forks, I would like another 1/2" off the front. It took a smart remark on here to get my buttons pushed to drop my stuff in. (holding out for long time for some Tokicos)
    I hope I gave some insight on some problems that you can have with doing it. Good luck to everyone & have air tools to make it quicker.
    LX User jonrichert's Avatar
    Aug 2003
    1987 Accord EF Extra(rhd) A18A
    Summerland, BC Canada
    my rear lower shock bushings are seized on as well, i still need to lower the back of my car..(and cut the forks because my h&r's aren't low enough up front)
    anyone know if you can get these bushings seperately through the dealers?
  1. J's Passion: Finally Slammed On Koni Sports Kit
    Last Post: 11-02-2006, 10:41 AM
  2. Lowered on Konis! Plus other suspension goodies
    By frantik in forum Classic Honda Pics & Videos
    Last Post: 09-27-2006, 11:46 PM
  3. finally getting the suspension taken care of
    By ryan88lxi in forum Suspension/Wheels/Tires/Brakes
    Last Post: 02-11-2004, 07:25 PM
  4. ALL Techs Help me out here!
    By 88 RaceCar in forum 3geez Accords
    Last Post: 07-13-2003, 09:28 AM
  5. Honda Techs
    By Sabz5150 in forum Classic Honda Community Chat
    Last Post: 08-13-2002, 08:49 AM
