Results 1 to 10 of 10
Thread: Ingals rear camber kit
    http://www.ingallseng.com/parts/38600.htm
    Any one use this? I didnt think we could get the tie-rod end separate or do you think the picture is wrong? Like to start stiffen up the rear end a little.
    Maybe I answered my own question.
    http://www.ingallseng.com/misc_parts/84200.htm
    looks close.
    Vinny's Avatar
    Aug 2003
    Here, not there
    What Tie rod? You mean Ball joint? Yes you can get the rear ball joint seperate. Several members have the ingalls kits. I have one myself. Beck arnley sells one just like it
    Vinny's Avatar
    Aug 2003
    Here, not there
    PN for indivdual ball joints for the rear
    TRW 104211
    Beck/Arnley 1014714
    Moog K9736
    bullard123's Avatar
    Nov 2003
    1988 Hatch LXI
    COLORADO SPRINGS
    What about the front?? Most camber kits I see for the front are way too expensive. I have heard some members talking about using prelude control arms. Does this work pretty good?
    10/Honda/Ridgeline
    NJ
    i have seen some companies using stainless steel washers and arp custom long bolts to correct camber. From what i remember, one washer would like change 1/4" of camber. I was thinking of doing that way too. i dont really see any downfall to it, as long as the bolt is strong enough and long enough.
    Yes i mean ball joint sorry.
    I think the washers work with lowered cars mines not. Im looking for negative camber in the rear (maybe). But really I like the look of that arm its solid and it has poly bushings and by eye I think I can make solids if i want to. The stock arm that would be hard( not impossible) to do and that bushing is way to soft for me.
    I have the front kit it looks like the ingalls kit but is made by another company I cant remember off hand. I like it pretty well but the adjusters just have 3 holes so you are kinda stuck with what you have.EDit One hole for negative camber and 2 for positive. I really think you can switch the left and right side and get a lot more negative camber if you wanted. I think i have like -2 and -2.25 I remember there not exactly the same. I think thats plenty for a wishbone setup. tire wear is excellant with that setup.
    Quote Originally Posted by Vinny
    TRW 104211
    Beck/Arnley 1014714
    Moog K9736
    thanks dude
    google says $7.58 thats a deal. I have been going thru the upper rears every other year for like for ever.
    Vinny's Avatar
    Aug 2003
    Here, not there
    I pick up most of my moog stuff at rock auto, they have very good prices and quick shipping
    10/Honda/Ridgeline
    NJ
    for better turn-ins, negative camber upfront and positive camber in the rear help a lot and without eliminating the understeer which our cars are prone to have, u need either stiffer rear swaybars or just some stiff ass spring (rear of our car is 981lbs).
    For the balljoin, i think u need like a press to press those ball joints in.
  1. rear camber kit
    By geej07 in forum Suspension/Wheels/Tires/Brakes
    Last Post: 01-30-2010, 01:49 AM
  2. how low is too low to use rear camber kit
    By mykwikcoupe in forum Suspension/Wheels/Tires/Brakes
    Last Post: 06-03-2009, 09:00 AM
  3. Possible rear camber kit
    By ICEMAN707 in forum Suspension/Wheels/Tires/Brakes
    Last Post: 06-11-2005, 01:50 AM
  4. Rear Camber Adjustment Kit
    By sausage2003 in forum Suspension/Wheels/Tires/Brakes
    Last Post: 09-30-2003, 08:13 PM
  5. Q: rear camber kit...
    By markmdz89hatch in forum Suspension/Wheels/Tires/Brakes
    Last Post: 09-10-2002, 06:18 PM
