Results 1 to 14 of 14
Thread: waterpump performance gain? on ebay
    SEi User myaccord7's Avatar
    89 honda accord LX
    Quincy,IL
    i found this on ebay. looks nice. is it worth it?
    http://cgi.ebay.com/ebaymotors/ws/eB...MakeTrack=true
    zach
    Mike's89AccordLX's Avatar
    Mankato, Minnesota
    I don't think you will feel any performance gain. Anytime you replace old worn out parts it helps the car run better. So if you need it or are changing the timing belt then go for it.
    SteveDX89's Avatar
    2002 Mazda Protege5
    New Freedom, PA
    It doesn't claim to add performance to the car. It says it's performs better than the stock pump. Either way, it's about the same price as a regular one so you might as well try it. Also, the water pump is driven by the alternator belt so you can change the timing belt separately from the water pump.
    Moodybluesr's Avatar
    Jan 2004
    1991 Subaru XT6 AWD, 1988 Subaru XT6 AWD
    Urbana, IL
    Stock cast iron pump? Our stock pump is aluminum... that and the guy lists it for 85-89 Accords... I don't see anything special about this auction.
    Vanilla Sky's Avatar
    1999 Penalty Box
    looks just like the 2 stock ones i've installed
    Mar 2005
    88 LX-i
    NC
    What is there about any 3g water pump that could make it more performance then another unless it flows more or weighs less and based on the size of these how much weight loss? Are you using this vehicle for racing or driving? I've never had a problem with the Honda water pumps but as previously stated--cheap as a typical aftermarket--go for it!!!!
    A20A1's Avatar
    Sep 2001
    2006 Chevy Cobalt LS
    I'd like to see the fins/blades on the opposite end... but they don't have a pic.
    SEi User
    Jan 2004
    water pump
    yeah pics of the impeller would be good, the best type is the cast impeller much better flow the std ones with the bent steel impellers aren't as good. But if you want the best then blank off the water pump housing, and fit an electric water pump, you'll save from frictional loses and benefit from having a constant flow of water and no cavitiation of the water at high revs.
    Nov 2002
    Ridin Dirty in New York
    ive never seen anything but stamped impellers for accord pumps. An electric water pump would be nice but the reliability of such an item usually reserves it for race only.
    A20A1's Avatar
    Sep 2001
    I only use cast impellers... I had the bent tabs on my other accord but I swapped it once it gave out.
    About the electric pump... where do you route the new lines to and from the pump unit?
    Nov 2002
    a20... where do you get cast impeller pumps for the 3g? With an electric pump you put it inline in the radiator hose
    A20A1's Avatar
    Sep 2001
    GMB... I think is the name.
    SEi User 2old_honda's Avatar
    Nov 2002
    88 Accord
    Nebraska
    Quote Originally Posted by A20A1
    correct. GMB brand pumps have the cast impeller
  1. performance chips on ebay
    By AccordNut in forum Performance
    Last Post: 12-28-2004, 01:49 PM
  2. Performance Chip? (Not the ebay resistor)
    By Volitech in forum Performance
    Last Post: 08-31-2004, 02:55 PM
  3. waterpump problem
    By jstyle711 in forum 3geez Accords
    Last Post: 06-17-2003, 01:17 PM
  4. If you change your waterpump
    By spaz in forum 3geez Accords
    Last Post: 05-27-2002, 08:40 PM
  5. timing belt change=performance gain?
    By Chrome_thangs in forum Performance
    Last Post: 05-17-2002, 11:50 PM
