Hey you guys. I didn't search so if it's been mentioned like a thousand times I'm sorry. Just in a big panic! I have a 1000W amp that is 2-way bridgable. I then have 2 500W Subs. I wired everything like the instructions said to. I used 4guage wire from the battery to the amp and 8guage to ground the amp. Not sure what guage I'm using to go from the amp to the subs but, that's not the problem. The problem is that the amp is recieving power. I checked it with a multi-tester and the power light is on. The problem is that where you connect the wires that connect to your subs there is no power. I would assume that this is an amp problem. It recieves the power but, doesn't distrubute it. If anyone can help it would be great. Thanks
