I have a problem with my clutch. Its engagement point seems to shift from time to time for reasons I do not know. I have had the car for 7 weeks. When I first got it, there was no play in the pedal. I adjusted it to have play. Then I R/R'd the valve cover gasket and the clutch started slipping. The cable was adjusted again. For a while I had it so the pedal play was good and it engaged fairly near the fllor like it should. Now it has play and engages higher.
Could this be the cable going wierd or is it likely the clutch disc/pressure plate/release bearing needing replacement, or both?
227Kmi, '88 Accord LX.
Thanks,
Brian
