Results 1 to 3 of 3
Thread: hard shifting
    hard shifting
    I posted before about hard shifting. Someone suggested the tranny was getting ready to call it a day. After some thought, I want to add, the SHIFT LEVER is hard moving. It isn't hard to get it into gear, but the lever is hard moving front to back. The only place that's loose is right to left in neutral. I removed the console/boot and sprayed grease on the ball, but it's still hard to move. I'm thinking there is a pivot point on the shift lever that I can't see from underneath cause it's like a tunnel back into where the arm attaches to the bottom of the lever.
    Any thoughts on where to grease?
    shepherd79's Avatar
    Falling Waters, WV USA
    you can't grease anything. everything is inside the tranny at this point. what kind oil is in it? if you use too thick of oil it will make shifting too hard.
    Quote Originally Posted by jayshonda
    There's a rail that goes from the shifter to inside the transmission you can clean this and make sure that it is clean. The small dust boot maybe ripped.
    With the car off and the clutch in you should be able to throw it back and forth pretty easy.
  1. hard shifting
    By Holy^ghost in forum 2geez Accords
    Last Post: 08-14-2007, 08:20 PM
  2. auto trans shifting really hard
    By twistyrider in forum 3geez Accords
    Last Post: 07-25-2007, 08:50 AM
  3. Hard to shift, grinds when shifting into reverse
    By 86lxifixage in forum 3geez Accords
    Last Post: 11-15-2004, 08:10 AM
  4. Shifting Problems
    By 88LX-iSedan in forum 3geez Accords
    Last Post: 05-12-2003, 03:11 PM
  5. Shifting the RPM.
    By AccordSi in forum Performance
    Last Post: 01-15-2003, 03:47 PM
