Incorrect. The torque the engine produces remains the same, it just takes less time to accellerate, in other words, it gives better accelleration overall. The myth that you loose torque is hard to kill. Tell me - why would the engine suddenly produce less torque by just changing the flywheel? It doesn't make sense, right? The only thing that changes is that you have less mass in motion to push the car off the line. But when you are off the line and the engine tries to change rotational speed (ie. accellerate), it has less mass to bring up to that speed; the change of speed happens faster - ergo, better accelleration. Similar sensation as to running very light wheels.Originally Posted by SteveDX89
It's all in *where* material is removed. If you remove material from the center section - sure it gets weaker. But if you take material off from the edge (see those lips near the starter ring gear?) the flywheel actually gets *stronger*. Hard to believe?I'm not the machinist but I think anymore weight loss and you're going to begin to compromise the wheel's integrity.
Look at it this way - rotating mass is experiencing sentrifugal force - the faster the flywheel spins, the more the outer mass tries to rip the flywheel apart. Now, if there is less mass far out on the flywheel, the ripping sentrifugal force exerted on the more inner parts are also less.
