Ey, all..
The inline fuse to my H/U, and the ECU/Clock fuse (#11, engine compartment) keep blowing. (Not both, it's always one or the other.)
See, the thing i don't get is everything worked fine last time i drove the car.. Wich was about a year ago, and none of the stereo has been touched since. Now that i went through and put a new head gasket in, this is happening. (I'm quite sure i didn't over-look any wires, or connections that i disconnected.)
The only idea i can gather, is a bad ground.. I already tried grounding the H/U to a different spot rather than the ground wire coming into the car, but that only seemed to burn a fuse faster. ...I'll probably try hooking the H/U straight to the battery, and see if it still blows a fuse.
Matt
