MoonScryer
I had the exact problem. replaced the EGR valve, various sensors, etc. It was not the problem.
There is piece called the Constant Vacuum Control (CVC) Valve in the "black box" (the thing with all the vacuum hoses going to it) that goes bad after a time. You need to replace this. It cost me $60 from the local dealership. I also replaced the Air Chamber that was attatched to it by a small piece of vacuum hose, also in the black box; that chamber was $5.
Took me 5 mins in the dealership parking lot to put it on. Unscrew the top of the black box, pull out the guts with everything still attatched, remove the one screw attatching the CVC valve, turn the guts over, and work the hoses loose. Put it on, put it all back together. Oh, watch the black box, sometimes it's a bitch to get the vacuum hose router thing in the right place.
Reset the ECU (pull the battery clamp off), and the check engine light went away after that. Simple.
