I found it in russian honda forum and just tryed. Results are fine!
And you spend money only for carb cleaner (3-5 $).
If you know russian you may look at
http://www.hondamotor.ru/board/index...%DD%CB%C2&st=0
Here I' ll try to explane it. It will save you a couple of bucks.
1. Take out injector (It's very easy).
2. Take any carb cleaner (spray can) and connect it to the injector.
3. Use any DC 12 V, 250-300 mA (not more then 2 A)power supply or battery. Do not use car battery or you will burn out your injector!
4. Connect power supply to the injector contacts (us I understand polarity doesnt matter). It's better to use button switch.
5. Just spray carb cleaner into injector. In closed position it should not leak.Press switch and open injector for few seconds. Repeat it as many times as you want.
6.For better results leave injector with carb cleaner inside for 2-3 hours and repeat all the procedure.
