Results 1 to 11 of 11
Thread: Front Suspension play???
    Mar 2005
    88 LX-i
    NC
    88 LX-i, when driving lower speeds 30-40 mph, the front end feels like it drifts back and forth. I can feel in the steering wheel when it sways from one side to the other, when it sways to the particular side the vehicle pulls to that side. Once corrected won't feel same for a little while and then will start again. Doesn't seem to do this at 70-80 mph. I know this is a suspension issue, please don't tell me that. I am looking for any answers that may help pinpoint particular suspenion issues.
    LXi User BlueBead's Avatar
    May 2004
    '87 Carbed Hatch(RIP), 88 FI sedan w/ power group, '73 Jag w/ 350lump
    Vancouver Island BC
    Sounds like Ball joints to me. I'm having a similar issue and its my uppercontrol arm balljoint. Supposed to have changed it out a while ago, but I hate working in the rain.
    I get a delayed reaction when making turns and a serious wiggle when I lay down some torque.
    2.0Si User Neuspeed87lx's Avatar
    Jul 2001
    96 Civic (Turbo lsvtec) /87 accord lx/95 civic dx
    Agawam, Mass
    worn tie rods, worn ball joints, broken sway bar/links ? alignment out ?
    Jay
    Mar 2005
    88 LX-i
    NC
    Quote Originally Posted by Neuspeed87lx
    That sums up most of the front suspension!!
    Mar 2005
    88 LX-i
    NC
    Quote Originally Posted by BlueBead
    I think you may be right, it feels like a floppy ball joint--thanks for the input
    Jul 2001
    Agawam, Mass
    well just put the car up in the air and check them !
    Jay
    Mar 2005
    88 LX-i
    NC
    Thanks
    Thanks for the blissful insight , didn't ask for smart ass remarks, but says alot about an individual--
    Quote Originally Posted by accord-ing to me
    Also do a front end check,
    1: jack up one side of the car till the tire is off the ground other tire must be on the ground still. I use the jacking point under the doors.
    2: grab the tire at the 3 and 9 o clock postion and shake/rock back and forth slow at first. might needsome one to help look underneath. This checks tie-rods,steering rack etc. start kinda slow and work your way up a little harder. Your looking for loosness. Use common sense of course the steering wheel will move or the other tire may move if you shake the shit outta it.
    3: Grab the tire at 12 and 6 o clock. Rock back and fourth.This checks the wheel bearing and ball joints other links
    4: this check might show ball joints/upper link a little better. Use a pry bar under the tire at the 6 o clock pos. pry up look for slop looseness while prying.
    This is your basic "front end check" any good mechanic should know. It works for all makes and models of cars
    Mar 2005
    88 LX-i
    NC
    OLDBLUE--I have done the first three with VERY little play. I haven't tried the fourth but really need to figure this out, car is starting to feel dangerous--might have to go to the shop!!
    Feb 2005
    87 Honda Accord
    Nampa ID
    I am getting the same issue. Mine pulls to the left most of the time but sometime it tries to veer right.
    I took it in and had it all checked out, aligned, and the subframe inspected. ( it has been a little to close to another car backside once or twice.) They came to the conclusion that it was the steering rack. Because it was not returning to dead center when you turned the wheel while sitting.
    This doesn't seem right to me. especially the pulling to the left. After the alignment it is pulling worse. The caster was off a little but that was all they found during the alignment. I also get a lot of wobble in the steering wheel at low speeds. They say that part is the tires. They quoted me $268.00 for a set of 13" tires. And $500.00 for a rack replacement. OUTRAGEOUS!!!
    But if what they said about the rack is correct it could part of your issue. Especially if it goes haywire without hitting a bump or dip.
    Hope this helps a little. They basically sat with the car idling and turned the wheel to the left, then to the right (About 1/4 turn each way) and looked to see if it returned to the same place every time. After dojng the baljoint and tie rod inspection.
    Oct 2003
    88 Accord LXI (low mileage engine)
    Vermont
    Bump,
    I wonder if sticky/squeaky balljoints might cause odd steering characteristics?
  1. Creaky Front Suspension
    By Haxxorz in forum Suspension/Wheels/Tires/Brakes
    Last Post: 09-15-2011, 12:06 AM
  2. Front suspension overhual
    By 86dxhatch in forum Suspension/Wheels/Tires/Brakes
    Last Post: 05-03-2011, 02:14 PM
  3. fs: front suspension bushings
    By rbeaud in forum Trading Post
    Last Post: 01-27-2004, 10:57 AM
  4. Front suspension = $900?
    By 2Fast4U86 in forum 3geez Accords
    Last Post: 10-19-2003, 10:04 AM
  5. knocking front suspension lx-i
    By ERIC in forum Suspension/Wheels/Tires/Brakes
    Last Post: 11-15-2002, 05:33 PM
