hey
I have a Pacesetter header and i'm having a little bit of a problem with my exhaust. A couple of times the nuts have fallen off of the bolts holding the header together (where it bolts together between the block and the radiator. What kind of bolts/nuts should i be using for this? none of the one's i've tried so far have stayed on. Its really freaking loud once it gets one of the nuts off. Should i be using something like lock-tight?
I noticed that 2 of the 3 bolts that hold the 'hi-flow' cat (test pipe) onto the resonator have dissapeared as well. what kind of bolts should i use there?
thanks for the suggestions.
