Results 1 to 5 of 5
Thread: tinting dilemma
    Jul 2002
    1989/ honda accord/ lx-i/ 4- door
    los angeles
    tinting dilemma
    The tinting on my rear windshield is bubbling up with little air bubbles, and i cant get them out... i tried to go to a tinter and remove it but he said it would tear out the heat pads on the windshield.... does anybody know what i can do???
    DiRtYsUiTmAn
    Jul 2002
    89 SEI Honda Accord
    Attending college in SC but actually from the U.S. Virgin Islands
    Use a razor and cut little holes in it, flushing the air out. Perhaps use some water to have it stick to the windshield.
    Canman. Reppin for the VI till the day I die.
    Nov 2000
    You are probably not going to be able to make it look decent by "popping" the bubbles. Cheap tint looks fine when it's new, but a few years down the road it bubbles and/or turns purple.
    They are probably right about not being able to get it off without messing up the defroster grid. When I had mine done 11 years ago I noticed one of my grid lines did not work any more. I took it back to the tint shop and they said they could fix it by removing the tint and using some conductive paint to repair the open spot. Well, what I ended up with if FOUR grid lines that do not work. Make sure before you tint that the shop promises to replace the rear glass if they mess up the defroster! My tint still looks good and fortunately there are still enough good grids that the defroster is effective. I hardly ever need it, though, as it doesn't get cold here often and I keep my car in the garage.
    Good luck with it.
    10/Honda/Ridgeline
    NJ
    i want to do tinting on my car. what product is good?
    Jun 2002
    1988 Honda Accord DX
    South Dakota
    When I tinted at a shop, we would peel the tint off the best we could without a razor blade. As you peel back the tint, keep the glue side wet in an attempt keep it from pulling up the defroster lines. Use a blade to remove the small pieces of tint left, being careful not to touch the defroster lines. After all the tint was off, we would use the finest steel wool pad we could find to remove the glue left on the glass. Soak the glue with water for a few minutes, then rub the steel wool pad lightly across the defroster lines to remove the glue.
    << i want to do tinting on my car. what product is good?>>
    Any tint will turn purple over time. Just some are faster than others. The tint in the auto stores and Walmart are not good choices because they turn purple within a few months and are not scratch resistant. The best stuff you can get is only available at tint shops or maybe on the internet somewhere. Most shops should sell you some raw tint to do it yourself. You want the stuff that has scratch protection for the inside, exposed side, the store bought stuff does not have this. Lumar (no affilation) is OK because of the scratch protection and doesn't purple as quickly.
    1989 Corvette Convertible
    1988 Honda Accord DX sedan
    1996 Chrysler Sebring JXi Convertible **FOR SALE**
    Your Altezzas are ghey. ut:
  1. 4x100 conversion dilemma. AHHHHH!
    By Hazwan in forum 1geez Tech & Performance
    Last Post: 05-14-2012, 02:30 PM
  2. Daily Driver Dilemma: CA6 vs CB7
    By Joay in forum Classic Honda Community Chat
    Last Post: 09-20-2009, 03:52 PM
  3. My 1985 Accord: a bit of a dilemma...
    By John Sweeney in forum 2geez Accords
    Last Post: 06-17-2009, 12:42 AM
  4. Help me solve this dilemma/myth, neutral or gear?
    By Mario Calero in forum 3geez Accords
    Last Post: 03-27-2006, 06:50 PM
  5. My dilemma
    By NXRacer in forum General Engine Swaps
    Last Post: 07-17-2003, 03:31 PM
