Results 1 to 8 of 8
Thread: New cylinder head
    89LXi Honda Accord
    Northwest Arkansas
    New cylinder head
    I am putting my car back together this weekend. I blew my cylinder head about two months ago and finally all the parts are in. While I have the engine apart, what can I do to make it run better, faster, stronger?
    thanks!
    1988starter
    Guest
    Port and polish higher comp pistons mill the head a little.
    YK86's Avatar
    Oct 2000
    BC, Canada
    Clean out the intake manifold (probably lots of carbon build up), P&P, and get your injectors cleaned. Pistons will require bottom end disassembly which might not be a good idea if you don't have much money. Milling the head is okay too but if you mill too much, the cam retards itself since it sits lower (fixable with an adjustable cam gear).
    www.b20accord.com
    88 DX 5 sp
    Jackson, MS
    How much is a little? I've seen recommendations for .015 off the block and .025 off the head for civic engines and wondered if it would apply to the accord engines as well.
    Cheers,
    Roland
    Jul 2002
    Twin Weber DCOE Powered 88 Honda Accord LX
    Columbus, OH
    ssophab, I'm interested in the follow up on this. Did you get the head ported and polished? If so, what kind of differences has this made? Please describe it fully, if you don't mind.
    As far as milling the head goes, has anyone done this? I know funstick has said not to mill the head. I'm new to the ideas of "cam retard" and adjustable cam gears fixing the problem. If anyone knows about this stuff, please share!
    Mike Clark
    LXi User 1989se-i's Avatar
    89 Accord SE-i Coupe
    Jokelahoma
    Would "double gasketing" help any?
    Performance Modz: Short Ram Air Intake, Custom Exhaust w/o Cat & Resonator, Cherry Bomb Turbo Muffler, Accel Coil, Removed AC
    Other Modz: Clear Blinkers, Purple Calipers, Accord Emblem On Dash, Winking Headlights
    LX User Volitech's Avatar
    Oct 2003
    91 civic hatchback JDM ZC swap, Yamaha FZ600
    Madison, WI
    Originally posted by Site
    ssophab
    As far as milling the head goes, has anyone done this? I know funstick has said not to mill the head. If anyone knows about this stuff, please share!
    That's what I'm wondering about! I have a new head on the way and i'm considering milling it! But how much should I mill off? .02 or .03?
    87 prelude si A20a3
    michigan
    Double gasketing is a bad idea. It won't seal properly and you will lower compression giving worse performance.
    87 prelude si
    87 non-turbo supra
  1. cylinder head
    By 88lxi-shortram in forum Wanted
    Last Post: 08-10-2010, 06:19 AM
  2. Rebuilt 2.0 Honda Cylinder Head Accord W/ Head Set
    By 88accordSF in forum 3geez Accords
    Last Post: 04-16-2007, 07:36 PM
  3. cylinder head tdc?
    By 86lxiricer in forum 3geez Accords
    Last Post: 05-03-2005, 11:43 PM
  4. cylinder head job
    By modu03 in forum Performance
    Last Post: 09-21-2003, 06:58 PM
  5. Cylinder head help!
    By DriverOnAcid in forum General Engine Swaps
    Last Post: 02-13-2003, 03:58 AM
