Results 1 to 8 of 8
Thread: Air Suction Valve
    DX User TTSpider's Avatar
    Mar 2005
    '89 LX Sedan
    Georgetown, CA
    Question Air Suction Valve
    Ok so ive had this buzzing or fast clicking noise under my hood and ive done some research. I think my air suction valve is the problem. What can I do about this? do i need to replace it or is there some quick fix i can do? I wish I could remove all my vacuum lines but im in CA It could be a little noise from my valves but i think most is from the AS valve. Thanks.
    Oct 2003
    89 Hatchback LX-i
    air suction valve? do you mean the PCV valve? they're like 2 bucks to replace...
    Chris
    http://personalwebs.myriad.net/mouchyn/accordsig.jpg
    Mar 2005
    '89 LX Sedan
    Georgetown, CA
    I dunno what its called but here its Air Suction Valve, and it seems to be making quite a noise.
    Nov 2002
    1990/BMW/535iA
    New Orleans, LA
    The air suction valve is not the same thing as the PCV valve. The AS valve controls the injection of fresh air into the exhaust manifold. You can simply disable it by removing the vacuum hose hooked up to it. Make sure you plug the hose. A new valve is very expensive, so it would be best to find a good working one at a junk yard. Hope this helps.
    P.S.: My AS valve has been disconnected for about 2 years with no ill effects.
    3axap.
    Mar 2005
    '89 LX Sedan
    Georgetown, CA
    awesome, i'll do that tomarrow. thanks for the help
    Oct 2003
    89 Hatchback LX-i
    forgot he was carbed... my bad
    Chris
    Mar 2005
    Nashville
    Is this supposed to always be quiet? I get a buzzing noise from under the hood sometimes. I thought it was normal.
    Brian
    '88 Accord LX 233Kmi '01 Cherokee 66Kmi '93 Toyota pickup 171Kmi
    '87 Accord LX 324Kmi parts car
    A20A1's Avatar
    Sep 2001
    2006 Chevy Cobalt LS
    The valve operates under 3,600 rpm to add vacuum as well as support emisssions. Our car has too many vacuum operated valves and such to run smoothly on manifold vacuum alone. As for being quiet... you may hear some noise... but there is a silencer (plastic tube) that is installed between the box just off of the valve and the airfilter box.
  1. Replies: 2
    Last Post: 10-17-2011, 08:57 PM
  2. Air suction valve removal
    By johnnygo in forum 3geez Accords
    Last Post: 06-24-2009, 08:21 PM
  3. air suction pipe?
    By nskforlife in forum 3geez Accords
    Last Post: 11-29-2006, 04:19 PM
  4. REALLY REALLY need EGR & Air Suction pipes !!
    By ZiggyxFresh in forum Trading Post
    Last Post: 02-22-2004, 10:39 AM
  5. He cut my #@!$%&* air suction tube....
    By 4DoorAccordDX in forum Carburetor Tech
    Last Post: 07-22-2003, 03:29 PM
