Hi everyone
got an electric weber dgv
I want to know exactly how you set the fast idle when cold
do you screw in the fast idle screw till it touches the cam when the choke butterfly is open or close? and set it to higher rpm than idle depending on the weather.
I tried it when the choke is closed so the screw touches the cam but the butterfly wont open cos of the screw and cam getting stuck. Also when engine is getting cold the butterfly wont close as the screw is on the way of the fast idle cam.
redline states that you have to adjust it when the butterfly is open but then it wont touch the fast idle cam....
Any advice would be great
Cheers!
