Results 1 to 5 of 5
Thread: Weber DGV Noise
    Apr 2005
    Weber DGV Noise
    my engine/carb is now making a "rumble" sound after the carby swap
    something like bru-bre-brap-bru sound when you let go off the throttle on speed around 60+ kph
    drives fine though, idles good
    checked the plugs (new), had it serviced
    any ideas?
    cheers
    A20A1's Avatar
    Sep 2001
    2006 Chevy Cobalt LS
    It depends... how is your setup now... what vacuum lines if any did you keep. Have you upgraded the fuel pump... when you close the thorttle vacuum jumps sharply for a few seconds before it settles to normal... this spike will pull your vacuum advace making changes in the timing.
    What rpm is the car at.
    Normally slamming the throttle closed when the revs want to stay high will create a void so you might get some exhaust pops and some intake pops, especially if you are firing too early.
    Make sure the PCV is still hooked up... other them that I'd need more info on your setup to make anymore assumpions on whats causing your noise.
    Apr 2005
    vacuum lines are connected
    engine is stock, fuel pump is stock I dont think I need a new fuel pump just for the weber swap as the stock pump can handle the weber fine.
    it normally happens around 2500 rpm +
    everything hooked up properly
    no backfire from the exhaust or carby just that air noise.
    A20A1's Avatar
    Sep 2001
    You sealed the coolant port on the manifold...?
    Apr 2005
    I did seal the port
  1. Odd noise
    By CzEcHy in forum 3geez Accords
    Last Post: 11-15-2010, 09:48 PM
  2. Noise
    By DBMaster in forum Classic Honda Community Chat
    Last Post: 10-28-2009, 05:56 AM
  3. Replies: 93
    Last Post: 04-25-2008, 10:42 AM
  4. odd noise
    By 87accordlx in forum 3geez Accords
    Last Post: 02-25-2003, 12:40 PM
  5. Irritating noise
    By Stefi-blueLX in forum 3geez Accords
    Last Post: 01-21-2003, 03:50 PM
