Results 1 to 25 of 38
Thread: dsm injectors?????
    SEi User adams86lxi's Avatar
    86 Honda Accord LXI 5speed
    so cal.
    dsm injectors?????
    Alright since my car is down right now i have been thinking up a better fuel management sytem for my car. I was thinking of maybe my fmu, bigger fuel pump and some bigger injectors would be good but i know you can make dsm injectors work with hondas but what moddifications need to be done for it all to work good??? I head something like you need to use resisters to get them to work but i have no idea??? Does anyone have any knowledge of doing this and btw how big of injectors do i need????
    http://www.myspace.com/3364524
    b20accord SN on honda-tech,homemadeturbo,clubcivic,turbod16, and many more
    Oct 2003
    89 Hatchback LX-i
    what kind of setup do you have? i assume you're boosted. how much boost? what other mixture management tools do you have?
    Chris
    http://personalwebs.myriad.net/mouchyn/accordsig.jpg
    10/Honda/Ridgeline
    NJ
    how much boost are you gonna be running? if you are gonna run even a max of 15psi, u can be satisfied with 450cc injectors. DSMs came in 450cc injectors. if you are gonna use less than that, u can still use those injectors, or get the 360cc from a VR4 3000GT, but they are hard to find (the car i mean). so ur 450cc injectors are fine. just get them from the junkard, send it out to get it cleaned and balanced for $25 each and thats only $100 for a set. Or u can prowl thru DSM forums to find a fairly used 450s.
    as for the resistors to run these high flow injectors, someone posted a link from the Honda-Tech of how to do it. THe first gen DSMs did come with resistor box and u gotta use that (its on their firewall) to operate these injectors. . also they should test at 2-3ohms at 68deg F
    you defenitely need to convert to OBD-1 to control these injectors the right way.
    if you look atht eht 6-49 chassis electical section of a 1990-94 turbo motor, it says that the injectors are controlled by the box and the box is wired up to the egr solonoid valve and then it runs to the ECM. So u might have to pull the egr valve too. (this was done only on the california model).
    PS: are you telling me you did not upgrade the fuel pump and the injectors when u were boosted???????? dude...................
    Last edited by smufguy; 04-13-2005 at 06:18 PM. Reason: Resistor box confirmation.
    so cal.
    Quote Originally Posted by smufguy
    I only want to push a maxium of 7psi. I went to 15 psi by accident. I was wondering exactly what would be the best setup for 5-7 psi.
    10/Honda/Ridgeline
    NJ
    well adamn, to be safe, run 450cc injectors with the 1g DSM resistor box. They run stock 11psi and people still push about 19 to 20 psi on their 14b turbos with the same injectors.
    along with the 450ccs, u need to get a 190lbs/hr pump, adjustable fuel pressure regulator, MSD ignition, Denso plugs or NGK BPR7 colder plugs.
    SEi User
    south dakota
    You don't need 450s for only 7psi. But if you want to upgrade anyway, so you won't have to in the future, the 450s are the blue tops from the 1st gen 5spd eclipse. You're going to need some electronics to control them, (not the dsm resistor box though, the factory accord injectors are peak & hold too) because they exceed the factory ecu's 30% correction factor, not to mention the factory ecu doesn't work with boost. I think I might have a set of 450s lying around..if I do, how much $ would you want them for?
    10/Honda/Ridgeline
    NJ
    he does not even need that T3 50 for only 7psi. He can run a bike turbo and be happy with it, lol. i was gonna say 370ccs, but hell 450s r available in any junkyard.
    SEi User
    south dakota
    and you don't need to upgrade the fuel pump with 7psi either, as long as you're not using a bs rrfpr. I ran more than 7psi with it, and I was running rich as fuck under boost. The stock pump is good to over 200hp n/a. If you want my opinion, to add up to 100hp, keep all your shit stock, and use supplemental injection, with 2 450cc injectors. Get the 034efi injector controller (300$), wire it up to your crank angle sensor, mount the injectors in your charge pipe right before your TB, tangent to the airflow, get an msd BTM, set it to a little over 1 deg/psi, and tune that shit to run about 11.5: afr under boost with a wideband. To fool the stock honda map sensor, go to radio shack, get a voltage regulator, set it to the same output as your stock map sensor under atmospheric, and connect it to the sensor output to limit the voltage input to the computer under boost. (easy) Of course you need other upgrades, exhaust, etc, but your shit will be fast, and your stock driveability/mpg will be unaffected. How do I know about this? Because I did it, before I went to a different management system.
    2.0Si User Elijah's Avatar
    Nov 2002
    A20A3T
    Edmonton, Ab, Canada
    Another good thing is the SMT 6 to use to manage those injectors I picked one up today. But you will need a laptop but you can get the SMT 6 for around $500 canadian mabey less I paid $450 it also controlls ignition its a nice little unit.
    here is a link if you want to research it abit www.perfectpower.com
    Stop bench racing and pick up a wrench
    I know my spelling sucks and I suck with computers deal with it.
    Nov 2002
    Ridin Dirty in New York
    you could do what accordtheory is saying, my setup is around the same price. If you wanna run 450cc injectors, just make the seals that fit in the intake manifold bigger (sand them out) thats it, the stock computer and wiring and fuel rail and all that shit are just fine for running them if you have a piggyback fuel controller. We already have a resistor box and are made to use peak hold injectors, so basically all we did was get a bigger injector. I use 450CC dsm injectors (bluetops), 255LPH intank walbro (its too big i think, but for boost a bigger pump will help, the stock pump maxes out at like 200hp... its like 70lph) umm i run an SAFC and a msd BTM and its been pretty good for driveabilty and adjustability, far better than an fmu could EVER be. Also bigger injectors will run like shit with an FMU setup. The 450cc injectors are good to roughly 300whp. Time to get real managemant adam... you dont wanna be pulling this engine apart again.
    so cal.
    alright cool. So all i need to do is just get some and there just plug and play no need for any extra resisters or anything good. So 450s wont be over kill for 5-7 psi?? And no matter what i need a safc to control them??? How user friendly is a safc??? How hard are they to hook up? I want one bad. Would it be better then my current setup to run just a safc with stock injectors???
    Nov 2002
    A20A3T
    You should really concider a SMT6 you wont need a BTM it controlls timeing to. Do a little reasearch before you spend the money. If you decide to go with AFC and BTM I will give you mine for cheap still. Where I got my SMT6 I can get more or you can they had 2 more in stock its my friends shop. www.apexmodified.com
    Nov 2002
    you cant run the safc and stock injectors for boost, youll need the 450ss, or at least 390s... I dont know too much about the smt6 but if its a good piggyback, go ahead and use it.
    so cal.
    well i think the 450s would be over kill for what i need (5-7psi) So i think im going to go with the dsm 390cc injectors from the automatic ones. Do you guys think i could run some 390s with out a safc or any other form of management until i get one???
    Also what model, years and stuff did the 390s come in so i can ask for them at the junkyard???
    Nov 2002
    i think 1G and 2g DSM turbo/automatic cars. The 390s will work just fine in piggyback setup (SMT6 or SAFC/VAFC), just dont try and use them with an fmu
    so cal.
    Quote Originally Posted by Elijah
    Elijah the sight isnt working? I want to check it out alittle more. How much would you want for the btm?? I might want to get it sometime. I have no idea what they sell for new??
    10/Honda/Ridgeline
    NJ
    Quote Originally Posted by adams86lxi
    http://www.apexmodified.ca its not apexmodified.com .
    Robs89LXi's Avatar
    May 2003
    '89 LXi Coupe
    Houston, Texas (Home of the Quicksilver project)
    Elijah, are you saying this SMT6 will piggyback off our stock PJ-0 ECU's? Does it use our distributor crank trigger? I'd like to know more about the details, specific to our cars. I was assuming it would only work with OBD-1 ECUs.
    "Feed their greed with your need for speed"
    Nov 2002
    A20A3T
    Quote Originally Posted by Robs89LXi
    It works with anycar. I will have it installed in a week or so and give an update on it
    Robs89LXi's Avatar
    May 2003
    '89 LXi Coupe
    Great. Yeah, I'm real interested in that unit, but all the research I've done on it shows it using OBD-1 ECUs. Be sure to document how you wire it real well, so that if it works good, you can add our cars to their list. Thanks.
    Nov 2002
    obd 1 piggybacks seem to work with obd 0 cars just as easily... i bet you could even get a Field Vtec controller to work just fine on our cars... but the safc/vafc is more tuneable and reliable
    Robs89LXi's Avatar
    May 2003
    '89 LXi Coupe
    What piggyback are you refering to? I've yet to see one that would work with our vaccum advanced distributor. How would it control the timing?
    Nov 2002
    most piggacks control fuel primarily... i guess its like a BTM and a fuel controller in one. I run my SAFC with a btm... not a prob
    Robs89LXi's Avatar
    May 2003
    '89 LXi Coupe
    Yeah, I see now that is probably what he will be doing, but that is a bit pricey for me for just fuel. I want spark/timing management too. I'm still planning to do the obd-1 conversion, so maybe I'll still look into piggybacking off of that.
    Nov 2002
    if your going obd 1, it would be a waste to use a piggyback, the tuning tools offered in obd 1 thru chipping (UBERDATA) are FAR more powerful as a tuning tool than a piggyback... Eventually ill go obd1 too, but i might put that off until i go BIG boost... (12+psi)
  1. 4th gen injectors
    By import racer in forum EFI Tech
    Last Post: 12-09-2011, 01:52 PM
  2. injectors and an FMU
    By newaccorddriver in forum Forced Induction
    Last Post: 06-27-2006, 06:08 PM
  3. injectors
    By gp02a0083 in forum EFI Tech
    Last Post: 12-30-2005, 11:40 AM
  4. Injectors
    By Pharoah in forum 3geez Accords
    Last Post: 02-17-2004, 11:26 AM
  5. 88 injectors on 86???
    By od2681 in forum 3geez Accords
    Last Post: 07-23-2003, 04:39 AM
