Results 1 to 3 of 3
Thread: headlight h4 pins
    88 LX-i HB
    headlight h4 pins
    Does anybody know the configuration for the pins? I'm pretty sure that the top one is always 12v? and the headlights are ground switched correct? Is the left high or low?
    Thanks.
    Apr 2005
    88 Honda Accord lxi
    Prescott Valley, AZ
    wiring for 84-85 prelude This is all I could find in the chilton.
    SE-i Sedan 5 spd
    I have the circuit diagrams for the '89, which should be the same as the '88. The hot leads for the high and low are switched. The ground(s) for the headlights are the middle sockets, with black wires. For the left headlight, the low beam wire is red/yellow and the high beam is red/green. For the right headlight the low beam is red/white and the high is red/blue. Good luck.
    Hal
  1. looking after a pistons/pins/rings set
    By ADRIANFARINA in forum 3geez Accords
    Last Post: 01-01-2011, 10:55 PM
  2. 250 bowling pins
    By bushbean in forum Classic Honda Community Chat
    Last Post: 08-16-2010, 05:07 PM
  3. door hinge pins?
    By mboardman in forum 3geez Accords
    Last Post: 10-05-2007, 09:10 PM
  4. Lube your caliper pins!
    By Gregg86DX in forum Suspension/Wheels/Tires/Brakes
    Last Post: 10-30-2003, 02:04 PM
  5. need info on ecu pins !!!!!!
    By Sean in forum Performance
    Last Post: 07-14-2002, 01:53 PM
