for those of you with the original vacuum boosters, what does your brake pedal feel like?
I just replaced my master cylinder, but my brakes still feel a little off. The pedal has quite a bit of travel, but it doesn't fade. Once the pedal stops, it stops. That tells me that the master cylinder is holding pressure, but the brake pedal on my sedan moves more than the pedal in my hatchy.
When i lay on the brakes at 60 mph, the car also wants to rotate. I don't know if that means I still have air in the lines somewhere or if the car just handles like that under heavy braking. The stopping power is good, i guess. It'll lock the wheels up just fine and won't fade at all even after a full day at the track. it's just doesn't feel even.
so, is the "mushy" pedal a problem with the 15 year old vacuum booster? with the car off, you can hear a very short "woosh" if you pump the brake pedal.
or is there still air in the lines? I bled all 4 brakes very thoroughly. I flushed all the old fluid out and put in dot 4 fluid. The bleeders pour very clean and clear fluid when I bleed them. That led me to believe that there wasn't any air in the lines, but the brakes don't seem to grab evenly.
slide pins are greased, pads are worn evenly, brakes have been maintained. The rear end just likes to slide around.
again, i guess i'm just used to my preludes. They have all new brake hardware, 4 piston calipers, and braided lines. those brake pedals are rock hard right from the top.
