mouchyn, thanks , I should have mentioned that to him.
Update, so far I have replaced the following with no change,
plugs,cap,rotor,wires & filters
throttlebody w/tps & fast idle valve
dizzy
both 02 sensors
ecu
vaccum control box (map sensor)
ignition coil and resistor
The resistor on the drivers side fender (metal box)
I've tested the following,
tps, and tw sensor, both in spec
I'm running out of options, what would be the best way to isolate if fuel or fire is being cut ?
I will also test voltage from the alt, back to basics.
