Hi,
On my 1988 Honda Accord LX, the front right (passenger ) side caliper is sticking. That caliper appeared to be "stuck" as the slide pins didn't work. The outer rubber on the brake line was peeling away. I replaced both calipers (rebuilt) and hoses (new) with Honda dealer parts. Bled air. Still, the right caliper sticks.
I test both by turning wheel manually and running the engine with the front end on jackstands, parking brake set. In gear, only the left wheel turns. If I stop the left wheel, the right wheel will start moving. But I'm thinking its the right that's supposed to turn normally.
Could this be a problem with the proportioning valve? Should I just remove it and R/R with one from my parts car or a new one from the dealer? Suggestions needed!
Thanks,
Brian
