I have a problem with my #1 cylinder on my Se-i. It has no compression so I think it's a valve or gasket or hole in the cylinder. When you take the head off do you have to take the intake manifold off with the head then unbolt the bottom nuts on the manifold to get it off? Can the bottom nuts that hold the intake manifold on the head be removed while the head is still on the block? I don't want to take the intake manifold out with the head if I don't have to.
