Quote Originally Posted by 89turbo'ed
put everything back on...
look durectly under the dizzy there is a window on the bell housing of the tranny.
get a flashlight shine in the hole.
you'll see a pointer on the engine side of the flywheel.
get a friend to help you out, pull the plugs out and put a ratchet on the crank pully bolt turn counter clockwise real slow.
you should see the timing degree marks first, then you will see a mark that say's TDC or TC.alighn that with the pointer, and your done.
before you put on the timing belt make sure the up mark on the cam gear is at 12:00 with the head. I.E. in line with the valve cover bolts..
Thanks. My cylinder head is off, and I don't see the window. Is this from the top, or underneath?
