Results 1 to 8 of 8
Thread: Exhaust Gasket??
    Feb 2005
    88 dx sedan, RIP... 89 LX-i Coupe... 99 k20/k24 ek hatch
    Manalapan, NJ
    Exhaust Gasket??
    Is there a gasket that goes b/w the flanges of the different sections of the exhaust pipes? i pulled down the one from my sedan(after nothingi tried worked on the bolts and i just sawzalled that bitch) and there was no gasket. would it be a good idead to put a gasket or does it really not matter? lemme know.
    shepherd79's Avatar
    Falling Waters, WV USA
    if i remember correctly, where header meets downpipe, there are 2 metal rings that make tight seal.
    Feb 2005
    Manalapan, NJ
    i didnt pull down that piece juss the rear most pipe. the flange thats right under the rear passenger's door.
    -joe
    May 2003
    88 Accord LX 88 Accord LXi
    There should be a round gasket that fits inside the groove in the flange.
    if your talking about the triangleish shaped flange then yes. its an O shaped gasket. its not the same one as the 2 gaskets on the catalytic converter or 1 on the down pipe. it is the same on carbed and fi models. $5-$9 from honda, i'd just get a felpro one from a parts store. that's what i've used and they work good with no leaks when you tighten the flange down to spec.
    Feb 2005
    Manalapan, NJ
    yea i found the gasket it was buried in rust. thanks for the info guys. neone know what the torque specs are on those bolts?
    -joe
    May 2003
    You are talking about the last flange before the muffler, right. If so the torque is 16 ft lbs.
    SEi User BMS's Avatar
    Nov 2002
    88 LX / 97 Teg
    California
    I took my muffler off once and when I put it back on I just got it fairly tight. There's not really anything that you over-torque, and being under torque shouldn't do much. I usually just get things about as tight as they were when I took it off.
  1. leaking exhaust manifold gasket
    By w261w261 in forum 3geez Accords
    Last Post: 12-14-2006, 05:08 PM
  2. exhaust gasket leaking
    Last Post: 10-27-2006, 08:12 PM
  3. Exhaust manifold gasket
    By fl_lunatic in forum EFI Tech
    Last Post: 06-30-2005, 05:35 PM
  4. Making an exhaust gasket?
    By 4DoorAccordDX in forum Performance
    Last Post: 12-24-2003, 11:36 AM
  5. Copper exhaust pipe gasket?
    By Mike's89AccordLX in forum 3geez Accords
    Last Post: 07-15-2003, 04:44 PM
