Hello, I have a 87 accord, 5 speed but the passenger side half shaft is busted open. I have a 86 accord with a automatic that we use for parts. I was wondering if the shafts are the same from an automatic to a 5 speed. thanks. Chris
auto shafts are different from 5 speed shafts.
Chris
http://personalwebs.myriad.net/mouchyn/accordsig.jpg
The passenger side half-shafts are the same. The driver side shaft is 7 mm longer for the AT.
Mike
really? honda gave me an automatic shaft seal by accident and it didn't fit at all...Originally Posted by AZmike
Chris
You're right. The left sides are different. And the right sides are the same.
I've only worked much on 5 speeds Accords. The factory service manual only shows a length diference for the auto half-shaft so I'd assume that's the only differnce other than the damper on the passenger side 5 speed half-shafts.Originally Posted by mouchyn
Mike
As others have said, passenger side axle is the same, AT or MT.
The shaft seal is not a good indicator. The ID is probably the same, but the OD is probably different between the AT differential and the MT differential.
Brian
'88 Accord LX 233Kmi '01 Cherokee 66Kmi '93 Toyota pickup 171Kmi
'87 Accord LX 324Kmi parts car
