Page 6 of 8 FirstFirst ... 2345678 LastLast
Results 126 to 150 of 191
Thread: Body Kits
  1. #126
    Apr 2004
    88 LX, 17"x7.5" Enkei 205/40's, Custom fabbed Seamless body front to back, shaved trunk, waiting for 3-Stage Candy paint to be applied
    Canada
    If that's the avenue you wanna go,,then go for it....Gonna be a lot of work to fabricate and fiberglass a whole bumper...just remember before you attempt the whole piece is gonna have to be blanced......left side = right side.....if you have a mold fabed right it will work....
    Do NOT use a lot of filler to create you pieces....BAD IDEA! Spend the time and figure out how you are going to create your custom mold for the fibreglass work...This is your base and it's very important...if you don't have the patenice to work out imperfections,,,and the frustrations associated with the messinees of fibreglass...it will be a disaster...
    #1 Tip:
    Use Foam Insulation in a can to create customs molds,,,but note it is messy (sticky) as hell and it doesn't like the vertical forces of gravity...prepared to get messy....but when cured it's get to shape,,,can be cut, sanded,,,it's great!!
    Damm never thought of taking any pics when I fab my customs molds,,,wish I did..sorry guys...
  2. #127
    Apr 2004
    Canada
    Lightbulb
    #1 Tip:
    Just waiting for my Tri-Coat paint and supples I ordered.....Base it going to be Metallic Silver BC with Candy paint over top then Cleared...gonna be sweet!!
  3. #128
    1988 honda accord
    portland indiana
    I got a spyder kit for my 88, 4dr and i wanna talk to someone whose put one on, cuz its no simple bolt on, I think im gonna have to make my own brackets for it
  4. #129
    LXi User Gemini2003's Avatar
    Jan 2004
    Kelowna BC Canada
    I actually thought of that... (Foam Idea) you mean like mono foam right? What is the importance of equal weight on both sides?
    Aswell how many layers would be considered minimum? and what would be considered the maximum ammount of layers?
  5. #130
    Apr 2004
    Canada
    Quote Originally Posted by Gemini2003
    Any type of insulating foam in a can will work...3-4 layers min. you can use as much as you want...I wouldn't use more then 6 layers...can get pretty thick...
    Yah the Spyder bumper has to be customized to fit our cars....defietly use some type of lower brackets by the fender wells..they have a tendency to bounce...
  6. #131
    Apr 2004
    Canada
    When I say balanced, I am referring to creating one area that is identical to the opposite side....this is were custom molding is time consuming....one side looks great but then you have to fabricate and duplicate the other one to match up...could be a disaster.....
  7. #132
    Jan 2004
    Kelowna BC Canada
    I'm sorry I should have been more specific....
    "As well how many layers would be considered minimum? and what would be considered the maximum amount of layers?"
    (Referring to the fiberglass laying itself)
    I know it's dependant on where you need the strength but is it advisable to do a minimum of 2 layers of fiberglass ?
  8. #133
    1988 Honda Accord LX-i
    philly
    heres my car domain site, i have the spyder kit on there.
    http://www.cardomain.com/ride/2110099
  9. #134
    1989 honda accord 2 door lxi 5 speed
    NJ
    Re: Body Kits
    I am looking for a kit for an "89" 2 door accord ware can i find it
  10. #135
    NJ
    Re: Body Kits
  11. #136
    3Geez Veteran gfrg88's Avatar
    1986 Honda Prelude 2.0Si-T
    A Mile High.
    Re: Body Kits
    dude read the damn thread!!!
    -Gio
    My E85 Turbo Build
    5280FEST
  12. #137
    Re: Body Kits
    hi, i'm new and i'm just wondering if anyone knows where to get a bodykit for a 1985 honda accord hatch. my uncle just gave it to me and i'm trying to make it a project ride. thanks!
  13. #138
    DX User Aer0deck's Avatar
    Re: Body Kits
    doesn't body kits ruin the aerodynamics?
    i's still not sure if i should get one.... and if i relly want to get a body kit i will go to a specialized tunner to make something really special!!! i just need the money!!!
  14. #139
    Accord of the Year - 2009
    thegreatdane's Avatar
    Jan 2003
    Denmark/Europe
    Re: Body Kits
    Aer0deck, where are you from?
    Link to my 3geez garage
  15. #140
    Re: Body Kits
    its a secret... far far away from you guys
  16. #141
    DX User Lockleaf's Avatar
    Feb 2002
    1990 Nissan 240SX w/ VG30DETT
    Utah
    Re: Body Kits
    Laying glass for strength depends on a couple of things.
    1. curves add strength
    2. number of layers depends strongly on weight and weave of glass.
    Fiberglass comes in many different weights (this refers to thickness) and weaves that are better applied for different purposes. Thinner glass will mold more complex designs. Thicker glass will require significantly less labor. You can also get glass that is woven tightly or loosely like fabric, or you can get glass that is woven like plywood - every which way. Straight rigids lays are better done with plywood weave. They are stronger. Curvy lays are better done with fabric woven, it bends and molds more predictably.
    I've only done small projects in glass, like a set of custom speaker pods in my brothers 91 civic, but so far that is all I've picked up. If somebody knows more or sees need to correct me go for it. And if you really want to know about forming glass, go to your nearest boat repair and construction shop. Nobody throws glass like a boatbuilder.
    Later.
    Lockleaf
  17. #142
    Re: Body Kits
    i think the aerotech bodykit should go on here
  18. #143
    DX User JeepinGoose's Avatar
    Re: Body Kits
    just thought I would throw this out there, in case it wasnt allready known
    http://www.grounddynamics.com/mercha..._body_kits.htm
  19. #144
    1988 Accord LX-i
    Delaware County
    Re: Body Kits
    Quote Originally Posted by JeepinGoose
    That was already posted a few times.
  20. #145
    Mar 2006
    Re: Body Kits
  21. #146
    1988 Accord LX-i
    Delaware County
    Re: Body Kits
    How hard it will be to make it fit all depends on how much you know and how skilled you are. If you do body work and bodykits a lot then it won't be too bad, If you have never done anything like it before then you will probably not want to buy a complete bodykit and start cutting it because there is a chance it won't work. What you should do is go to the junkyard and buy a bumper off a 90-93 accord and see how hard it will be to customize it, because then you will be able to figure out wether you think your confident enough to put out the money and try or maybe decide doing a custom kit will be too hard. There are a couple companies that sell bodykits for the 3geez if your interested in that.
  22. #147
    bullard123's Avatar
    Nov 2003
    1988 Hatch LXI
    COLORADO SPRINGS
    Re: Body Kits
    Quote Originally Posted by Aer0deck
    What??? Where did you hear that? Bodykits and spoilers improve aerodynamics.
  23. #148
    DX User H22AccordSE-IV's Avatar
    1989 Accord Se-i
    Mississauga, Ontario, Canada
    Re: Body Kits
    Check this out...the 02-05 Civic and the 04-05 1.7 EL have the same lip, rocker (or whatever you call it) under the doors, ours just sticks out a little further, so there would be a slight gap between the skirt and the doors. Only 3 cm needs to be cut off the skirts' length to make 'em fit our cars. I'm lookin' at a set of 1.7 EL skirts - they retail for $857.00 a pair which is a little fu*kin' rediculous, but I found 'em on clearance for only $184.00!!! Apparently the 1.7 EL wasn't that popular so Acura is clearing out all of its accessories at up to 80% off.
    http://img85.imageshack.us/img85/332...lskirts7lg.jpg
    I also managed to custom fit a 94-97 Accord Stillen Touring lip on the original 3rd gen bumper. Don't laugh, but I cut pieces off of a plastic paint tray to extend the lip on the sides, just need to mould everything together. Check out the pics and tell me what y'all think.
    http://img88.imageshack.us/img88/4382/lip14lk.jpg
    http://img97.imageshack.us/img97/3883/lip25is.jpg
    http://img97.imageshack.us/img97/8985/lip37rd.jpg
    I'm workin on a flush headlight conversion as well and Photoshopped a few concepts. Also included a pic of the headlight cover I cut, but still haven't decided how to mount it. As of now I have 2 Hella 90mm headlight modules (low beams) temporarily mounted on the original brackets for the retractable headlight assemblies. Still workin' on fab of the new bracket to mount both high and low beams.
    http://img109.imageshack.us/img109/7...rsioniiiic.jpg
    http://img109.imageshack.us/img109/6203/hlcov15jl.jpg
    http://img109.imageshack.us/img109/796/h22084ib.jpg
    An H22 swapped into a 3G Accord is the kind of stuff you only read about in fairy tales.
  24. #149
    Re: Body Kits
    ohhh dam dude thats going to look sweet!! keep us updated
  25. #150
    1989 Accord Se-i
    Re: Body Kits
    Thanks, Cheese. You know I will!
    G.
  1. body kits?
    By twizted_ninja in forum 2geez Accords
    Last Post: 11-22-2006, 05:53 PM
  2. does anyone know what this body kits is??
    By 87RedAccord in forum Interior & Exterior Care
    Last Post: 08-21-2004, 09:27 PM
  3. body kits
    By ninja2571 in forum Interior & Exterior Care
    Last Post: 12-10-2002, 07:00 PM
  4. Body Kits
    By accordexi87 in forum Interior & Exterior Care
    Last Post: 07-17-2002, 03:11 AM
  5. body kits
    By poseymon in forum Interior & Exterior Care
    Last Post: 07-02-2002, 01:06 PM
