Results 1 to 5 of 5
Thread: 86 lx-i sputters
    1986 honda accord lx-i
    denver co
    86 lx-i sputters
    sometimes when i take off from a stop my enginf sputters and thecar dont want to move usually the only way to get it to go is by pushing in the clutch and reving the engine til it seems normal anyone know what might cause this
    DX User A20A3inside's Avatar
    Mar 2005
    1986 Honda Accord LXi HB
    Fayetteville, NC
    Have you run your gas to empty or right above empty a lot? sometimes if you do that in older cars such as ours....the screen on the end of the fuel pump will get clogged. try taking out the fuel pump, (access under the trunk floor mat on the upper level toward the front of the car are 2 circular lids) and get a can of air and blow the rust and what not off the screen. let me know if it helps
    Just because she's old, don't mean she's ugly!
    86LXItooFAST4me's Avatar
    Dec 2003
    1986 Accord LX-i *** 2002 Mustang GT
    Austin, Texas
    do a tune up and go from there. plugs, wires, cap n rotor, oil change, all filters. and maybe clean the TB.
    "Seriously, I have a half o' pack of Rolaids in my dipper" -Stewie (Family Guy)
    Car Pics
    vBGarage
    DX User syclinsam's Avatar
    1986 / Accord LX-i / Hatchback! & 89 SEI 5spd sedan
    i agree with these guys. the first thing i would change is the fuel filter, then dist. cap, rotor, plugs, wires. I bet one or all of these will fix the problem. you should definetly do the rest of the tune up, but this might hit the nail on the head.
    1987 honda accord lx-i hatchback
    pompano bch, fla
    you should pull the access cover off your pcm, under the back of your driver's seat and see if that little red l.e.d. is flashing any codes at ya. then replace your ignition's secondary circuts. cap rotor wires and plugs. while oil and air filters should certianly be kept clean and fresh, they will seldom cause misfires. if a clogged fuel system were the problem, it'd make sence it'd break up at higher speeds, not off the line. maybe it might also behove you to pull your valve cover and double check all your timing marks, and check the condition of your timing belt.
  1. Still Sputters!!
    By Scotts88WhiteLX-i in forum 3geez Accords
    Last Post: 06-22-2003, 08:05 AM
  2. Sputters wtf?
    Last Post: 06-15-2003, 03:52 AM
  3. car sputters...why?
    By superaccord in forum 3geez Accords
    Last Post: 01-28-2003, 12:38 PM
  4. Car sputters...
    By Nospeed in forum 3geez Accords
    Last Post: 12-12-2002, 10:05 PM
  5. Car sputters
    By rob49 in forum 3geez Accords
    Last Post: 11-25-2002, 02:50 PM
