There are 2 marks on the drive plate (AT) which u got mixed up..
- a "T" which is the Top Dead Center (#1 cylinder). This is used to setting crankshaft sprocket when installing timing belt.
- a "i|i" which is the ~15* advance from "T" mark, and is used when setting the timing (with a light..).
BTW, i replaced my fuel pump 2 days ago, and as u said no warning whatsoever. Had to tow the car home
I got a CARTER P72190 pump. When i got old one out it was identical with new one. So i wonder how reliable are those CARTER fuel pumps?
